core support #1584599
02/26/14 07:22 PM
02/26/14 07:22 PM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
How difficult is it to change the radiator core support? Upper and lower sections. Lower section was replaced with a rusty junkyard piece and the upper is bent. Lower appears to be tack welded in. Will this require supporting / bracing the frame rails before disassembly or should I not worry about the front assy. becomming out of square or moving around? Car is still together now but no engine. '69 Bee.
Re: core support [Re: BeeSuper] #1584600
02/26/14 08:56 PM
02/26/14 08:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you have the car on jackstands at the trans crossmember then you should be ok. I'm at that stage right now - inner fenders are out and the support coming out tonight. Nothing has moved on mine but you'd be wise to take measurements if you're taking the inner fenders out. If you're not taking those out then there really isn't anything that should move as those provide all the support.
Re: core support [Re: BeeSuper] #1584601
02/27/14 01:08 AM
02/27/14 01:08 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Be careful when changing out that upper core support. If you still have your vin numbers stamped on the top, it would be a mistake to change it. Id get it straightened out by a good body man.
Re: core support [Re: fastmark] #1584602
02/27/14 10:15 AM
02/27/14 10:15 AM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
A good body man I am not, never done it, no skills, don't wanna learn the hard way on this car. Yes the numbers are there but they are also on the trunk rim above the driver quarter and the entire drive train is non #'s matching any way. It could probably be bent back in shape though.
Re: core support [Re: Stanton] #1584603
02/27/14 10:23 AM
02/27/14 10:23 AM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Am I correct in thinking that the lower portion is spot welded to the frame ends? Mine appears this way but the repair is obviously not factory. It's pretty cheesey work at best and heavily pitted with prior rust damage and nothing else on the car is. Thanks for the info. Oh by the way, the K-member is out, the car is on a lift but all sheet metal is still in place.
Re: core support [Re: BeeSuper] #1584604
02/27/14 11:52 AM
02/27/14 11:52 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yes, it is spot-welded on the ends. You'll likely be doing that with a mig though.
Re: core support [Re: Stanton] #1584605
02/27/14 12:22 PM
02/27/14 12:22 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
If replacing the entire core support I would weld a brace from frame rail to frame rail on the bottom to keep them from moving and either weld or bolt something across the top to hold it. Just cheap insurance that way you know it doesn't move and of course measure 12 ways to Sunday to make sure it held. I would also do what I could to save the original core support especially the section with the numbers.
Careful, your character's showing!
Re: core support [Re: mopar346] #1584606
02/27/14 11:10 PM
02/27/14 11:10 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
The K-member makes a perfect brace. Neither rail can drift in, out, up or down.
Re: core support [Re: BarrsRestoration] #1584607
02/27/14 11:27 PM
02/27/14 11:27 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
bolt the k frame back on
its the perfect brace for that repair..
then do your work on the front.
Re: core support [Re: flypaper] #1584608
02/27/14 11:58 PM
02/27/14 11:58 PM
mopar346 Offline
mopar346  Offline
I would still be conerned about the top, it want take any time to brace and then you know you're good.
Re: core support [Re: mopar346] #1584609
02/28/14 12:23 AM
02/28/14 12:23 AM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Fix it, splice around numbers section if necessary, but I would spend money to keep original
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: core support [Re: BarrsRestoration] #1584610
03/04/14 11:27 AM
03/04/14 11:27 AM
Fairhope, Alabama
BeeSuper Offline OP
BeeSuper  Offline OP
Fairhope, Alabama
Good idea, thanks for the help to everyone.
