Page 2 of 3 1 2 3
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581599
02/20/14 08:53 PM
02/20/14 08:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's an April '68 Dart GTS
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581600
02/20/14 08:55 PM
02/20/14 08:55 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& a July '68 hardtop Road Runner.
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581601
02/20/14 10:10 PM
02/20/14 10:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Wrong color on the console top...
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 Inland Shifter question. [Re: Rhinodart] #1581602
02/20/14 10:52 PM
02/20/14 10:52 PM
Bristol, CT
RalphsRapidTrnst Offline OP
Bristol, CT
Thank you
So a December built RR would most likely have been delivered with an Inland.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: 1968 Inland Shifter question. [Re: Rhinodart] #1581603
02/21/14 02:19 AM
02/21/14 02:19 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& there are "rumors" floating around about the "reality" of the car itself
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581604
02/21/14 03:12 PM
02/21/14 03:12 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The original owner 1968 rr I bought in 1972 had the hurst shifter with a reverse light. It also had a white shift knob that I have been told was wrong but I am not totally convinced. My car was a hard top turbine bronze with white vinyl top, magnum 500 wheels, 26" radiator and 3.91 gear. It was original except for a dp4b edelbrock intake and scat track H-70 -14 tires.
Getting old just means you were smarter than some and luckier than others.
Re: 1968 Inland Shifter question. [Re: dannysbee] #1581605
02/21/14 10:28 PM
02/21/14 10:28 PM
New York, USA
Chargerfan68 Offline
New York, USA
I have a Dec 8, '67 SPD Charger that was completed later...engine, heads, tranny, k-frame all have 12/13 -12/21 dates and are original to car. It came with the Inland shifter...no reverse light in dash.
Re: 1968 Inland Shifter question. [Re: Chargerfan68] #1581606
01/01/15 01:47 AM
01/01/15 01:47 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
So is there a latest known Inland application in 68 B-bodies? I know of a 124 and 207 that are both thought to be factory Inland cars, 1 I can check for the reverse light tomorrow, the other it will be a week or so before I can look. Nothing would make me happier than for them to be Hurst cars.
Careful, your character's showing!
Re: 1968 Inland Shifter question. [Re: mopar346] #1581607
01/01/15 01:58 AM
01/01/15 01:58 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Assembly plant info would also help.
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581608
01/01/15 02:18 AM
01/01/15 02:18 AM
mopar346 Offline
mopar346  Offline
Looking at fender tags tonight not VINs so no plant info on there. Both were delivered to the East Coast one in Fl one in Pa if that helps.
Re: 1968 Inland Shifter question. [Re: mopar346] #1581609
01/01/15 02:38 AM
01/01/15 02:38 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
certain bodies were only built at certain plants & some noticeable differences between some plant's fender tags
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581610
01/01/15 02:42 AM
01/01/15 02:42 AM
mopar346 Offline
mopar346  Offline
Then I will report back with more/correct info.
Re: 1968 Inland Shifter question. [Re: mopar346] #1581611
01/01/15 08:50 PM
01/01/15 08:50 PM
mopar346 Offline
mopar346  Offline
I was able to verify no reverse light and an Inland shifter for the 207 68 R/T Coronet. The 124 car is a Satellite and I wasn't able to get to the dash today to check it.
Re: 1968 Inland Shifter question. [Re: mopar346] #1581612
01/05/15 01:14 AM
01/05/15 01:14 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
My '68 GTS was built Jan. 4th and came with an Inland.......
If you can't handle the truth, you're living a lie.......
Re: 1968 Inland Shifter question. [Re: Big Squeeze] #1581613
01/05/15 02:48 AM
01/05/15 02:48 AM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
I have in my archives an Inland 4-speed Charger with a SPD date of 2-29-68...I figure sometime in March the change was made to only install Hursts.
Dan
Re: 1968 Inland Shifter question. [Re: Dans 68] #1581614
01/05/15 10:32 PM
01/05/15 10:32 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
My 68 Charger RT has NO LIGHT and "had" and inland at one time but was replaced with a hurst. The build date on my fender tag is Jan-18.
Re: 1968 Inland Shifter question. [Re: Dans 68] #1581615
01/05/15 11:16 PM
01/05/15 11:16 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
My 1968 GTX has a build date of 108 January 1968 and came with the Inland shifter. Just removed it and installed a Hurst unit. Car was built at the Los Angeles Ca plant.
Re: 1968 Inland Shifter question. [Re: SCATPK] #1581616
01/06/15 04:20 AM
01/06/15 04:20 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
now we're getting somewhere!!
Re: 1968 Inland Shifter question. [Re: 6bblgt] #1581617
01/06/15 01:04 PM
01/06/15 01:04 PM
france
jose jones Offline
jose jones  Offline
france
My 68 GTX vert was built Dec 1,67 has original motor and transmission with a hurst shifter and no reverse light
Re: 1968 Inland Shifter question. [Re: jose jones] #1581618
01/06/15 01:26 PM
01/06/15 01:26 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Your GTX came with an Inland shifter and someone removed it and installed the Hurst setup.
Page 2 of 3 1 2 3
