Re: Template for DODGE on front of Challenger Hood???
[Re: CumminsGirl08]
#1581235
02/19/14 02:32 PM
02/19/14 02:32 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I made a template for a member over on CC.com. I think it's still floating around somewhere. If it can be found, I'm sure the person who has it would send it to you.
I just posted this on CC.com. We'll see if the template shows up.
[Re: CumminsGirl08]
#1581236
02/19/14 05:15 PM
02/19/14 05:15 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
I would look on www.phoenixgraphix.com they do a great job with decals for vehicles! and they have some Dodge decals done already
He's not needing decals. He needs a template as to where the holes get drilled, so he can install the (5) individual Dodge metal letters.
[Re: holtzdog55]
#1581238
02/19/14 06:49 PM
02/19/14 06:49 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
I found this on my computer that i saved a while back. Not sure if it's correct.
[Re: VoodooCLD]
#1581239
02/19/14 07:36 PM
02/19/14 07:36 PM
Posts: 445 Fairfield, Ohio
holtzdog55
Fairfield, Ohio
is that in centimeters?? cm? I guess the guy doing mine found where the holes were under the hood....drilled and they were good.....thanks for the help though....maybe this will help someone else out......
Finally Done....BEERS!!!
[Re: burdar]
#1581241
02/19/14 11:05 PM
02/19/14 11:05 PM
holtzdog55
Fairfield, Ohio
I'll take a copy if you don't mind ...for future use.....would have needed it if my hood didn't already have hole before .....my email is aholtzapple@cinci.rr.comThanks.
[Re: holtzdog55]
#1581242
02/19/14 11:20 PM
02/19/14 11:20 PM
Posts: 1,567 Ky
jt4406
Ky
I don't know if this will help, but I took these pics off my 70 challenger hood, with NOS letters installed:
Jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#1581243
02/19/14 11:21 PM
02/19/14 11:21 PM
Posts: 1,567 Ky
jt4406
Ky
I did not drill these holes, they were already there, factory stamped.
[Re: jt4406]
#1581244
02/19/14 11:23 PM
02/19/14 11:23 PM
Posts: 1,567 Ky
jt4406
Ky
The letters are parallel, they do not angle inward at the top, but are different distances from the front edge of the hood, as follows:
[Re: jt4406]
#1581245
02/19/14 11:25 PM
02/19/14 11:25 PM
Posts: 1,567 Ky
jt4406
Ky
the above pic is the first "D" in DODGE..
[Re: burdar]
#1581249
02/20/14 01:55 PM
02/20/14 01:55 PM
Posts: 460 Oklahoma
VoodooCLD
Oklahoma
The guy I made the template for still has it. He made a PDF of it if anyone else needs it.
I'm interested in a PDF.
