Found my surging idle demon #1580661
02/18/14 04:27 AM
02/18/14 04:27 AM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
65 New Yorker with a 413 and a Holley 600 carb. Car would idle up and down. Played with jetting, changed out power valve, block vacuum advance- all without any changes to the surging. Today I had the hood up listening to my surging beauty, Noticed I would hear a click right before it would idle up. Click-vroom. Click-vroom. Traced the sound to the- PCV valve. Pulled the valve, blocked the hose, and the surging stopped! Haven't run into a mystery PCV valve problem since the Plymouth Trouble Shooting contest years ago. Ordered a new valve online tonight. Hope that clears it up for good!
Re: Found my surging idle demon [Re: Carsavior] #1580662
02/18/14 12:22 PM
02/18/14 12:22 PM
I believe it will. You sure wouldn't suspect the PCV as the culprit for a vac leak & I've only ran into that once (it stuck wide open), tho the PCV is a controlled vac leak & from what I understand different ones have a different size orifice.
Re: Found my surging idle demon [Re: RapidRobert] #1580663
02/18/14 03:12 PM
02/18/14 03:12 PM
Cab_Burge Online work
Cab_Burge  Online Work
I like to use a PCV valve with a weak spring so it stays open anytime the motor is running Helps lean the idle out also in motors with big cams
