2000 Durango code P1491 diving me nuts
#158002
11/28/08 12:32 PM
11/28/08 12:32 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
My sisters Durango kicked on a CEL. O2 was weak and had a cooling fan issue. Replaced the 02, that codes gone now, but the P1491 was still there. Found the fan was shorted out and burned the B+ wire going to the relay. Fixed both issues, and now I can use a test light and ground the relay, fan kicks on fine if I make it. When running and you kick the a/c on no fan, pulling the pigtail for the coolant sensor wont kick it on either. All fuses are fin, swapped sme relays around, all them are OK too. Whats going on with this thing?
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
Re: 2000 Durango code P1491 diving me nuts
[Re: stumpy]
#158006
11/28/08 05:50 PM
11/28/08 05:50 PM
70dart360
Green Meister
Green Meister
Hampton, Ga.
I looked there due to some of the battery acid issues. Harness in clean, The fan will work if I ground the relay and thats the harness it goes through.
70 Dart Swinger
