Re: Braided fuel questions..........
[Re: astjp2]
#1579350
02/17/14 11:54 PM
02/17/14 11:54 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Each line has specific fittings for them, they are mostly 37* with others types being JIS and SAE 45*. You need to find the right fittings per the hose. Aeroquip and stratoflex have interchangeable ends, but most others are not made to the same standard. Tim
Will the Summit brand fittings that I have work on any other braided line besides Summit hose? I guess I will have to start over with new hose ends. Do all the hose ends for the Nylon braided line crimp on or do they look like the pic. I posted above? On the Summit web sight they do not say which ends go with each hose..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1579351
02/18/14 01:37 AM
02/18/14 01:37 AM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I just put some lines together with Aeroquip startlite black hose with Summit ends It was my first time using braided hose of any kind, was very easy to work with and seemed like the hose and ends were compatible [image]http:// [/image]
[Re: Thumperdart]
#1579353
02/18/14 09:35 PM
02/18/14 09:35 PM
D-50
North, Alabama
Thanks for all the help maybe I can get figured out. I guess I will order some of the parts tonight.
[Re: hemi-itis]
#1579355
02/19/14 02:30 AM
02/19/14 02:30 AM
Thumperdart
State of confusion
I use pvc cutters............... Just saw "bleeding" ya, no more stainless braided for me and of course the pvc cutters don`t work on that stuff but it`s excellent and quick on the nylon.
