Page 6 of 8 1 2 3 4 5 6 7 8
Re: why the hatred for the eddy 750 carb [Re: DaveRS23] #1577882
02/16/14 06:11 PM
02/16/14 06:11 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
You are confusing tuning parts with carb choices. There are very few CarterBrock choices for a given size of carb when compared to the Holley platform.
What new argument is this?
500, 600, 625, 750 and 800 cfm isn't enough? I'd wager you are covering most of the market there.
Granted a 850-1000 CFM would be very, very nice for stroker engines but don't see it happening anytime soon.
I have been watching the TQ knock off Street Demon from Demon/Holley with great interest though. I don't see them going over 750/800 cfm though due to being locked into the squarebore pattern and I doubt Holley wants poaching from their higher end products.
"I think its got a hemi"
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577883
02/16/14 06:17 PM
02/16/14 06:17 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
ok keep telling yourself that. A holley 750 DP/HP or even a vacuum would give him more HP.
Looking at Dwayne's dyno results its a wash.
http://www.moparts.org/Tech/Archive/bb/25.html
Facts are pesky things, they don't go away because you want them too.
If you picked up 2 1/2 tenths doing a carb swap of the same CFM you are doing something wrong in the first place.
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577884
02/16/14 06:22 PM
02/16/14 06:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll have to check but I think it's a 750, it's been on the shelf a while. I used part of it for a 750 rebuild like 5 years ago.
Can't you buy the Mopar M1 w/ a spread bore? I'd think a 440 w/ a 1000 TQ would be a good running car. I think QuickD has 2 on his Hemi.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577885
02/16/14 06:26 PM
02/16/14 06:26 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
A holley 750 DP/HP or even a vacuum would give him more HP. I have 3/4's of a holley 750dp in the garage. If somebody wants to buy the rebuilt kit and 2 fuel bowls, I'll rebuilt it and give it to him. If it doesn't run 2.5 tenths faster in the 1/4 mile I'll buy all parties involed a 30 pack of Bud.
Sam Adams Boston Lager, no Bud for me thanks.
I'm tempted to take you up on that offer- I have a well sorted out 750 AFB on the Duster and it needs a shake down this spring at Lebanon Valley after a carb, cam and trans swap.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577886
02/16/14 06:31 PM
02/16/14 06:31 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Yes, the M1 has a spreadbore pattern but if anyone is going to tool up and make a new carb they are going to want to have it fit a maximum number of vehicles and spreadbores are in the minority.
440 runs great with a TQ, I campaigned for years with an 850 on a TM-7 with an adapter plate. Back on the shelf waiting to be used again on a different car now that the GTX is sporting the tunnel ram again.
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577887
02/16/14 07:01 PM
02/16/14 07:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Now that you mention it, spreadbores are none existent in CarterBrocks. Again they are the simpler carb with less choices for those that like that.
But Holley and their partners are making more and more carbs with dual patterns. Including the new Speed Demon.
I just couldn't help mentioning it.
Master, again and still
Re: why the hatred for the eddy 750 carb [Re: DaveRS23] #1577888
02/16/14 07:05 PM
02/16/14 07:05 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Ahem.
You are aware that both the Carter and Edelbrocks AFB's also have a dual bolt pattern? And have done so for decades?
The new "TQ" from Demon is not a spreadbore carb, its designed for squarebore intakes. That's why the CFM ratings are so low (750 max), the secondary butterfly is limited to fitting the smaller squarebore opening.
Dual pattern and spreadbore/squarebore are two different things.
Spreadbore carbs never caught on in the market even though they are an excellent idea with small primaries and much larger secondaries. I doubt anyone would tool up to make a new design. You can sell just about anyone a squarebore carb but spreadbore the market is limited and there is plenty of Quadrajets out there.
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577889
02/16/14 07:23 PM
02/16/14 07:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The problem is there are more people that think they are sealed units than don't.
Then they are very much in the wrong hobby and are in the vast minority, perhaps its just were you live.
He had ZERO intention of using that carb , it was just a test to see where it was out of the box.
Wait- Did you not state "he knew his way around a carburetor" and now you are stating something else? huh.
Did you skip over the part where he swapped on the CARTER 750 , which you state is the SAME CARB, and the engine didn't run like a piece of crap ?
You have reading comprehension issues my friend, I stated they were virtually the same castings. Jetting, metering rods and spring rates make a huge difference.
But again ZERO INTENTION of running that carb either. A strip kit is just jets, rods and springs, it does nothing if the carb itself, with incorrect size internal passages, is the problem.
And you know this how? You picked a poor example "as proof" and display a bit of ignorance about how the AFB's are constructed. I have a problem taking your word on the subject as to the shortcoming of this particular carburetors design. On the other hand I own several Edelbrock and Carter AFB's and they all work great and have rebuilt and tuned several hundred over the decades for a living (including Holleys, TQ's and AVS not to mention non-mopar stuff like quadrajets and even the horrible VV carb from Ford!) for other people without issue.
A single example in which the user freely admits making no changes to the unit is not a sweeping indictment on Edelbrock carbs.
I find it amusing that people will spend vast amounts of time on Holley carbs "drilling this circuit" or "swapping out this air bleed" or "trying this modification" but won't spend some time learning how AFB's work which are the simplest of devices.
But that's ok, more for me ;-)
Oh sorry , you are the king of carb tuning , everyone else on the planet is an IDIOT compared to you .....
I'm out , you're
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577890
02/16/14 07:25 PM
02/16/14 07:25 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Ahem.
Still, spreadbores are non existent in CarterBrocks. They are simpler with less choices.
But you're right that they bolt onto both styles of intakes, there is no dispute there.
I am not sure that I would agree that the new Street Demon is not a spreadbore or that it was designed for square bore intakes. Or that spreadbores never caught on. Demon claims it was designed for both, hence the GoogleValve or whatever they are calling it. There is certainly a large difference in the primary and secondary bores.
Tell ya what; if you don't want to call it a spreadbore, why don't we call it a Google bore? And we'll note that it was designed by a former Carter guy.
Any chance that will make you happy?
Re: why the hatred for the eddy 750 carb [Re: Cab_Burge] #1577891
02/16/14 07:26 PM
02/16/14 07:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think most of you guys commenting on the Eddy 750 forget who Edlbrock sells a majority of the carbs to, it is not Mopar people
WINNER !!!!!
Re: why the hatred for the eddy 750 carb [Re: DaveRS23] #1577892
02/16/14 07:52 PM
02/16/14 07:52 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Why on earth would they make a product there is virtually no demand for? I mean if thats a plus for Holley then by all means take it.
How many spreadbore carbs does Holley sell every year? 1 in 100? 1 in 1000? I'm betting closer to 1 in 1000 than 1 in 100 considering how many regular flange carburetors they have for sale. I might have handled one or two spreadbores Holleys in my life and both were on RV's.
It's clear it isn't a spreadbore carb like the TQ or Quadrajet. They tried to make it like them (very small primary & very large secondary) but were limited on the secondary side due to the width of the squarebore opening, that's why it has more of a blade to maximize the cfm on the secondary side.
Will it fit on a spreadbore intake like the M1 with a large hole?
Sure, so would any AFB or Holley. The secondary blade on the street demon is no wider than a common squarebore intake opening though unlike a TQ or Quadrajet. I can bust out some gaskets for a comparison if you like.
People trying something new always makes me happy! Innovation is a wonderful thing and its nice to have more options not less in the marketplace.
I give Holley a big thumbs up for bringing it to market.
Now make a 900 cfm model =)
P.S. I have no particular animus against Holley, I like some of their products very much (like I stated already, have three of their carbs on the shelf) and there is features they have which are nice to have (always liked the sight glass for fuel level, external adjustable needle and seat which is also removable for cleaning) but other features are less desirable to me such as puking fuel everywhere during jet changes, popping power valves, gaskets below the fuel line and the air/fuel ratios tending to be on the fat side all the time.
Since in my experience (mirrored in Dwayne's dyno results) there is no real hp difference between a properly tuned Holley and a properly tuned Carter of the same size I prefer the Carter since it has better transitioning between circuits, the fuel is contained in the bowls (no gaskets to leak) and no power valve to blow out.
If I were to install a Holley of the same CFM as the AFB currently on there and picked up an incredible 25 hp (2.5 tenths) I'd leave that sucker on there.
Fair enough? Trying to be diplomatic here, but some of you are asking me to disregard 30 years of carb work under my belt, Dwayne's dyno results and the class racers who have also chimed in. Not going to do it.
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577893
02/16/14 08:23 PM
02/16/14 08:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What if !!
Re: why the hatred for the eddy 750 carb [Re: DaveRS23] #1577894
02/16/14 08:24 PM
02/16/14 08:24 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Oh that reminds me, can't run Holleys front to back on most low profile dual quad intakes but then again only streetrods run those!
<cheesy grin>
Re: why the hatred for the eddy 750 carb [Re: 62maxwgn] #1577895
02/16/14 08:25 PM
02/16/14 08:25 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
What if !!
Old 3 blade Pontiac?
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577896
02/16/14 09:02 PM
02/16/14 09:02 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
1st place 14 feet 3 inches
2nd place14 feet 1 1/2 inches
3rd place 12 feet 5 inches
etc.
etc.
etc.
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577897
02/16/14 09:48 PM
02/16/14 09:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And the comment on air bleeds has been missunderstood. I have never monkied with air bleeds..is that better for you?
Not what you said and not misunderstood.
It becomes more evident the more YOU post that YOU do not know how to tune a carb, therefore the too rich out of the box Holley is perfect, for you.
Don't be the exception.
Re: why the hatred for the eddy 750 carb [Re: DaveRS23] #1577898
02/16/14 11:05 PM
02/16/14 11:05 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
This is a really sophomoric argument.
Arguing which 1950s technology is superior. The Holley 4150 platform first saw wide service on Phord's Thunderbird. And AFB stands for Aluminum Four Barrel because they dated to a time when carbs had cast iron bases.
The CarterBrocks are simpler carbs that have far fewer sizes with very few choices. But, when right, they are extremely dependable.
The Holley style platform has far more sizes available. And a ton of different combos in each of those sizes.
As far as tuning, I don't think that there are a heck of a lot more guys that understand carbs today than there were 40 years ago. So the way it runs their car OOTB determines whether it rocks or is crap. More luck of the draw than precise planning or tuning or even brand.
Having said that, I am getting ready to buy the carb designed by a former Carter engineer working for a subsidiary of Holley; the new Street Demon.
That way we all win!
That is funny!!
Since Edelbrock did pick up where the Carter/Weber people left off. And funny that he perfected a carburetor design from them also. The Aluminum Four Barrel is unique because of it's self adjusting secondary air (flap) valve. Works automatically to engine airflow demand. A mismatched/poorly tuned motor combo will NOT allow this type carb to perform flawlessly. Is it an "all-out" carb? No...but AGAIN, it can deliver outstanding performance when PROPERLY tuned for the street, strip or both!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: why the hatred for the eddy 750 carb [Re: Mr.Yuck] #1577899
02/17/14 12:17 AM
02/17/14 12:17 AM
Onalaska, Wi
sixtyninefuchs Offline
Onalaska, Wi
"480 calculated flywheel hp isn't too shabby considering he is grossly undersized on carburetor CFM, I bet it has wicked throttle response."
You hit the nail on the head. He'd make much more power with a better carb. A 750DP or even better HP would give him much better performace. Even a thunder 800 would..
I'm glad somebody brought up Thermoquads. I love them, however finding a good one seems hard these days.
FWIW a big 4bbl would probably run better on my car, but I've always wanted a 6-pack, I can't afford a hemi
How about I go through the misery of rebuilding my 4781 AGAIN (and hope it doesn't leak gasoline all over my engine) I hate carbs that leak fuel....float bowls, 50cc accelerator pumps, blowing fuel out the vent tube from the smallest particle in the needle and seat, etc.
And what about the wonderful world of power valves (that can't stand up to todays fuels....although an alcohol power valve would probably work)
No thanks, I like my dirt eating edelbrock (14 years without ANY leaks, failed power valves, or needle and seat issues)
Oh, I forgot to say I have a 440 six pack as well (since 1990) and I love how it performs, just hate the maintanence.
Re: why the hatred for the eddy 750 carb [Re: gdonovan] #1577900
02/17/14 01:42 AM
02/17/14 01:42 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Most Holley's have blow out proof protection now
Re: why the hatred for the eddy 750 carb [Re: Supercuda] #1577901
02/17/14 01:50 AM
02/17/14 01:50 AM
Ontario, CANADA
hemi pwr Offline
hemi pwr  Offline
Ontario, CANADA
I have 2 600s on my and work great for me
1970 440-6 Cuda 71 duster 1999 Dodge ram diesel dually 1958 plymouth hardtop 1975 Fury 2 door 1970 AAR cuda clone
