ctd o4 trans pan #1577178
02/11/14 12:42 PM
02/11/14 12:42 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
who makes a pan with a drain plug for a reasonable price? all the ones i seem to find are 295.00 bucks
Re: ctd o4 trans pan [Re: bonefish] #1577179
02/11/14 01:35 PM
02/11/14 01:35 PM
Kansas
cascius Offline
cascius  Offline
Kansas
That's about what they all run. I've put on a ton of Mag-Hytec pans and never had any issues. The shop I worked at used the Double Deep pans on all our builds.
Re: ctd o4 trans pan [Re: bonefish] #1577180
02/11/14 08:55 PM
02/11/14 08:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: ctd o4 trans pan [Re: NITROUSN] #1577181
02/11/14 09:09 PM
02/11/14 09:09 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
http://www.lpwracing.com/Trans_Pans/Deep_Transmission_Pans.html
THATS more like it.is my trans designated as a TF-8?
Re: ctd o4 trans pan [Re: bonefish] #1577182
02/11/14 09:11 PM
02/11/14 09:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not just install a drain plug kit in your old pan? Most all parts stores carry the kit.
Re: ctd o4 trans pan [Re: bonefish] #1577183
02/11/14 09:15 PM
02/11/14 09:15 PM
Garry Owen Offline
Garry Owen  Offline
04 ctd is a 48re or g56.
Re: ctd o4 trans pan [Re: Garry Owen] #1577184
02/11/14 09:39 PM
02/11/14 09:39 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
but a 48re takes the same pan gasket as a 727 so a pan for a 727 will fit as long as it is deep enough.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: ctd o4 trans pan [Re: bonefish] #1577185
02/11/14 11:49 PM
02/11/14 11:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Buy a fluid evacuator.... It will literally empty the pan with the right length of vinyl hose. Use one at work all the time.
Re: ctd o4 trans pan [Re: dusturbd340W5] #1577186
02/12/14 12:02 AM
02/12/14 12:02 AM
Garry Owen Offline
Garry Owen  Offline
Good to know. Thanks
