Mopar Stge IV head picture #1574965
02/06/14 07:22 PM
02/06/14 07:22 PM
Cab_Burge Offline OP
I am posting these pictures on here to show a member on here what the Mopar Stge IV heads look like, Mods pleasse bear with me on this. Thanks Cab
Re: Mopar Stge IV head picture [Re: Cab_Burge] #1574966
02/06/14 07:23 PM
02/06/14 07:23 PM
Picture # 2
Re: Mopar Stge IV head picture [Re: Cab_Burge] #1574967
02/06/14 07:24 PM
02/06/14 07:24 PM
Last one!
Re: Mopar Stge IV head picture [Re: Cab_Burge] #1574968
02/06/14 10:26 PM
02/06/14 10:26 PM
gr mich
loren kraker Offline
gr mich
whats the difference between these heads and the 906??? thanks
Re: Mopar Stge IV head picture [Re: loren kraker] #1574969
02/06/14 11:37 PM
02/06/14 11:37 PM
Idaho
LaRoy Engines Offline
Idaho
In my opinion, the Stage IV is much like the 452 (flat roof) and the Stage V is more like the 906 (arched roof).
Re: Mopar Stge IV head picture [Re: loren kraker] #1574970
02/07/14 01:25 AM
02/07/14 01:25 AM
Not much that I know of This set has 2.14 intakes and 1.81 exhaust but I'm sure they where added later on, not stock out of the box
Re: Mopar Stge IV head picture [Re: LaRoy Engines] #1574971
02/07/14 01:27 AM
02/07/14 01:27 AM
gr mich
gr mich
What port do these come with???
Re: Mopar Stge IV head picture [Re: LaRoy Engines] #1574972
02/07/14 01:51 PM
02/07/14 01:51 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
First off I want to compliment you on the engines you built for the Mopar Muscle challenge!
Second which would make more power for a street/stip engine?
Pros-cons.
Thanks, Don
Re: Mopar Stge IV head picture [Re: cudadon] #1574973
02/07/14 04:32 PM
02/07/14 04:32 PM
Idaho
Idaho
Thank you for the recognition.
As the 906 has more potential than the 452, the Stage V has more potential than the Stage IV. Plus the Stage V has a much better exhaust port than the 906.
Re: Mopar Stge IV head picture [Re: loren kraker] #1574974
02/07/14 04:34 PM
02/07/14 04:34 PM
Idaho
Idaho
Does what come with?
Re: Mopar Stge IV head picture [Re: LaRoy Engines] #1574975
02/08/14 01:14 PM
02/08/14 01:14 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Chuck Millen at Best Machine and Dwayne Porter both ported a set of Stage V's back in around 2004 for myself and one other gentlemen. I believe the info is easy to find inthe tech archives by searching stage V. Also the exhaust port is improved as well (it's so shallow and tight radius ....it's amazing they could do much with it at all) and I believe the IV and V share the same exhaust port.
The Stage IV's as cast were not much better then the 906 however additional material was cast into the port roofs and built up on the floors to enhance the rather severere short side of the 906/452's. This was first done with the IV's and later further improved on the V's. Out of the box not much but when well ported they do start picking up around .400 lift and in the right hands the Stage V flows on par with a mildly ported Edelbrock.
The Stage V makes an awesome 500" stroker head, the improvements in the mid lifts add a lot of torque and extend the RPM range compared to a 452/906 that is ported to flow as well at say .550/.600, you just can't get the same mid lift numbers without the short-side radius improvements, not without some pretty extensive/expensive roof mods.
It's been about 30 years since I held a Stage 4 but I think they also cast them to reduce the pushrod pinch and required maybe a .100" offset intake rocker? Sorry, I'm trying to remember that far back but I think the V also had a smaller pinch but it didn't require the offset due to enlarging/bridgporting the pushrod pasages in the thicker as-cast port walls.
I'm sure Experts will chime in and tell me if my memory still serves...or not!
WIZE
In Car:
Re: Mopar Stge IV head picture [Re: LaRoy Engines] #1574976
02/08/14 10:54 PM
02/08/14 10:54 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
That nails it pretty good. I have s set laying around some where and that is what I thought. The stock stage IVs ports seem like mildly ported "smogger" heads without the "Hubber hump" on the port floor. The intake ports are a little taller than stock, but, not by much, and it has a "flat" port floor and low port roof much like a stock smogger. And the pushrods pinch is a little wider than the stock heads. Crane at one time made a slight offset rocker for the stage IVs. The stage IVs have maybe a little more meat for porting so a "Max effort" type port job and big valves may yield a little more flow than a smogger head ported to the same degree. The exhausts look like stock ports, just a bit bigger.
The combustion chamber looks about stock to me. Oh well, this is what I recall
Re: Mopar Stge IV head picture [Re: 6PACMAC] #1574977
02/09/14 12:51 PM
02/09/14 12:51 PM
ky
68roadrunner Offline
ky
my iv's cracked through the valve seat
Re: Mopar Stge IV head picture [Re: 68roadrunner] #1574978
02/09/14 02:06 PM
02/09/14 02:06 PM
warren, mich.
dwayne welder Offline
warren, mich.
Hello; Is that seat cracked on the exhaust?? I have one here to on the exhaust. It's a thin area under the short turn were there is very little metal for suport!!!! Another better idea form MOPAR!!! They never did have a clue what there were doing!!!! Have you had it fix yet, and how was it done. Thanks
Re: Mopar Stge IV head picture [Re: dwayne welder] #1574979
02/09/14 04:13 PM
02/09/14 04:13 PM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
This is going back 25 yrs (testing my memory here) but I ran Stage V's on my 500 inch 440 in a chassis car at 2400Lbs with a Glide. I spent all my money on the short block and had to scrimp on the heads (there weren't many options anyway back then). I believe with just a gentle port opening and some bowl work we got them flowing in the 280-285 range. I did use a Crane offset intake rocker and 2.14/1.81 valves.
The difference on the V over the IV in addition to the better exhaust port already mentioned was the oil passage was smaller dia so the pushrod was able to move over a little if I recall correctly.
It was a great combo, it would run 9.50's/9.60's at 140 with a 1.28 60 ft. Through the years I have seen guys with better heads not go any faster. I think the port velocity must have been way up there and it just plain worked.
Re: Mopar Stge IV head picture [Re: dwayne welder] #1574980
02/10/14 01:26 AM
02/10/14 01:26 AM
ky
ky
i really dont remember which seat it was in, that was years ago
we did pin it at the time, and it lasted a little while then went to seeping again, the machine shop said it was a thin area
they are on the shelf out there somewhere
Re: Mopar Stge IV head picture [Re: 68roadrunner] #1574981
02/10/14 01:15 PM
02/10/14 01:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
stage v's tuned up by dwayne porter
intake exhaust
.1-72.5 .1-57.2
.2-148.2 .2-117.1
.3-212.2 .3-168.2
.4-256.3 .4-200
.5-278.7 .5-202.5
.6-290.2 .6-204.9
Re: Mopar Stge IV head picture [Re: lewtot184] #1574982
02/10/14 03:10 PM
02/10/14 03:10 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here's my intakes with 2.19" intake valve (which I think enhanced the mid lift flows (265 cfm @ .400 is really pretty decent):
Stage V's (ported)
.100"--75.6
.200"--159.4
.300"--221.7
.400"--264.6
.500"--280.
.600"--285.5
.700"--289.9
WIZE
In Car:
