Retorque cylinder heads? #1573650
02/03/14 06:33 PM
02/03/14 06:33 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
I have my motor out replacing my headers and checking the trans. The motor has been together for two seasons. approx 130 passes. No problems. Iron block with iron heads and ARP head studs. Should I retorque the head studs or leave it alone? It has Felpro 1009 gaskets.
Lee
Re: Retorque cylinder heads? [Re: Lee] #1573651
02/03/14 06:37 PM
02/03/14 06:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd leave them alone... its been running fine.. dont
break it now
Re: Retorque cylinder heads? [Re: Lee] #1573652
02/04/14 12:01 AM
02/04/14 12:01 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've done it both ways, run the motor without testing and retorqueing and have retorque them once thsy came off the dyno. You know you want to check them correct Now is the time to do it, I would set the torque wrench to the same spec as before and check all of them Let us know the results, there are some members who swear you MUST ALWAYS retorque, esepcially with composition head gaskets and other like Mrpbody and me who will go either way on this subject
Re: Retorque cylinder heads? [Re: Cab_Burge] #1573653
02/04/14 12:22 AM
02/04/14 12:22 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I don't usually re-torque them. However I did check them on a Hemi I sold to a friend. We had used Aruzza composite gaskets on it. I was glad that I checked it as there were some stud/ nuts that needed tightening.
After this, I checked the torque on my Hemi that has Cometic gaskets and not a single nut moved!
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Retorque cylinder heads? [Re: Hemi Allstate] #1573654
02/04/14 09:36 AM
02/04/14 09:36 AM
gregsdart Offline
gregsdart  Offline
If you go through the pattern one stud at a time, backing them off a quarter turn and then going right to the proper torque in one move there won't be any chance of disturbing the gasket, and it may show some of them loosened a bit. I am not betting on much change at all, based on the iron heads. But it can't hurt, and you will know for sure next time.
Re: Retorque cylinder heads? [Re: gregsdart] #1573655
02/04/14 12:49 PM
02/04/14 12:49 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I always re torque in the method that Greg outlined above. Loosen them one at a time, 1/4 turn. You'll be suprised how much more than the 1/4 turn it takes to get back to full torque.
