Trans converter quesion
#1572860
02/02/14 01:15 PM
02/02/14 01:15 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
Okay.. My issue is I wanted to replace the stock converter in my U code Challenger with a sightly looser one. So after doing some searching I bought a 11" TCI. From what I remember the 383 and the 440 727's received the 11.75" or 12 inch converters??? I do remember this topic from once before, and I think it was about stall speeds and such????? So, my issue is... the converter mounts don't line up with my flexplate holes? I know I'm gonna need a different flexplate, but the question is from what? Hoping John K. will chime in and help me! Lol... Once I get the tranny pulled away from the engine again I'll do some comparisons wth the old one since I wasn't smart enough to do that to begin with... I just would have thought the ring gear and converter mountng holes would've been the same and just the converter diameter would change??? Thinking maybe the one I have is incorrect for me? TIA
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Trans converter quesion
[Re: MoparJunkie]
#1572863
02/02/14 03:21 PM
02/02/14 03:21 PM
RapidRobert
Was the dia of the 4 plate holes too small (904 plate) & wouldn't fit the larger "circle" of the bolt hole pads on the 727 converter? & as you know it has to be clocked to the right position for all 4 holes to line up (Not being patronizing just checking). What's going on?
[Re: SportF]
#1572864
02/02/14 03:44 PM
02/02/14 03:44 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
There is two mounting patterns for the converters, small and big. Sounds like you went from one size to the other. I am sure you already noted as well that the bolts and mounts only line up one way, that is the converter holes and flex plate only line up in one of 4 positions, eh? Also, there can be different size bolts for the different converters, I believe going from 3/8, 7/16, to 1/2 inch as well. Good luck!
Almost all (all I've seen) aftermarket converters are based on the smaller pattern. As long as you're at it, get a good flex-plate. The stock ones will crack. I use this one...... http://www.ebay.com/itm/B-M-PERFORMANCE-...be2&vxp=mtr
[Re: RapidRobert]
#1572865
02/02/14 07:58 PM
02/02/14 07:58 PM
MoparJunkie
The issue is they are about half an inch shy of meeting the holes in the flexplate all the way around... That's why I was wondering if the diameter was an issue? What I mean is if I measured a half inch directly above my holes and drilled holes it looks like it would bolt up? Like I said earlier they are on a smaller diameter measurement. I'd like to keep my stock flexplate... I'm wondering if I even have the right converter. I'll post more when I get it out to compare.
[Re: MoparJunkie]
#1572866
02/02/14 08:30 PM
02/02/14 08:30 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 10 3/4" (11") converter uses a flexplate with a 10" bolt circle, the 11 3/4" (12") uses a flexplate with a 11 1/8" bolt circle.
The 440 used the larger converter, HP 383 used the smaller converter. Redrilling the larger flexplate for the smaller converter is doable but I'd get the correct one.
[Re: John_Kunkel]
#1572867
02/02/14 09:46 PM
02/02/14 09:46 PM
MoparJunkie
Any ideas where I can get one???
