Re: Lil Red stacks on my ramp truck
[Re: Rhinodart]
#1571571
02/01/14 01:37 PM
02/01/14 01:37 PM
Posts: 20,339 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I don't think either of them look good at all, but the first version looks less bad. Just my $.02. If you like it, that's what matters.
Earning every penny of that moderator paycheck.
DBAP
"They don't think it be like it is, but it do." - Oscar Gamble
[Re: not_a_charger]
#1571572
02/01/14 02:21 PM
02/01/14 02:21 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Jim, The soot will be a real problem, After 15 yrs the stacks are rusty on my Warlock... why dont you donate them to your old truck?
[Re: sthemi]
#1571573
02/02/14 02:19 PM
02/02/14 02:19 PM
Posts: 15,487 Florida
scratchnfotraction
I called dibs on them..
I will be honest and say they would look much better on a truck that came with them rather than my 85 which does not.. but 85 is the last yr for a stepside.
they would be less gooberish looking than the 2 sticks of pipe I was looking at to make a set of stacks with no shields though.
[Re: sthemi]
#1571578
02/03/14 10:16 AM
02/03/14 10:16 AM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
Especially now that I remember you said you put those "prince of darkness" injectors in that truck. They're called that for a reason.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Rhinodart]
#1571580
02/04/14 12:07 AM
02/04/14 12:07 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I say run the stacks, just turn them out about 45 degrees, or maybe more.
I had a stack on my truck for a long while, and when I towed soot wasn't an issue.
Plus in the mock up, I think they look really cool!
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
