Should thrust block be removed with green bearings? #1571453
01/31/14 10:56 AM
01/31/14 10:56 AM
Mid-Atlantic
Scatransit Offline OP
Mid-Atlantic
Those of you that use green bearings: Does the thrust block need to be removed in the diff? I'm mostly concerned with '66 & up 8 3/4 rears. Thanks!
[oo]======[oo]
Re: Should thrust block be removed with green bearings? [Re: Scatransit] #1571454
01/31/14 12:21 PM
01/31/14 12:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I didnt..
I am truckless..
Re: Should thrust block be removed with green bearings? [Re: Scatransit] #1571455
01/31/14 12:28 PM
01/31/14 12:28 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you are running second generation snap-ring style (MO-400/ST-400) green bearings, a stock housing, stock brakes and stock axles, you can leave the thrust block intact.
Re: Should thrust block be removed with green bearings? [Re: DoctorDiff] #1571456
01/31/14 02:47 PM
01/31/14 02:47 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
I took Doc Diff's advice and left it in, no problem.
Re: Should thrust block be removed with green bearings? [Re: Scatransit] #1571457
01/31/14 10:11 PM
01/31/14 10:11 PM
scratchnfotraction Offline
I swap back and forth on my 2 chunks..the 489-3.91sg has the block,then 742-3.23 open has no block.
I run the axle seals and I have run with out them a few yrs now with out seal... just the o-ring on the green bearing.. so far it has not leaked past o-ring or thru the sealed bearing.
it is better to run them for added protection against leaks but I boogerd the last set with a BFH and running without them till next gear swap.
Re: Should thrust block be removed with green bearings? [Re: Scatransit] #1571458
01/31/14 10:38 PM
01/31/14 10:38 PM
Mid-Atlantic
Mid-Atlantic
Thanks guys... I've installed the snap-ring style in a 68 Dart & 71 Challenger. No problems, but I was just curious. I was not aware of a non snap-ring style. I wonder if someone has a pic of one? After thinking about this, I was wondering if it would even make a difference if the thrust block was removed as a precaution? Appreciate the help!
[oo]======[oo]
