Quietest exhaust possible for 440?
#1571191
01/30/14 02:45 PM
01/30/14 02:45 PM
Posts: 254 Opelika, AL
JRs_Charger
Opelika, AL
Well, I decided to start driving my 440 powered charger after a few years, and I've quickly grown tired of the obnoxious exhaust.
Currently, its running factory manifolds, a 2.5inch full length exhaust with H pipe, two 40 series flowmasters, no resonators, and original exhaust tips. And its LOUD. I measured 92 decibels inside the cabin at a 60 mph cruise last week. That's ridiculous.
I'm totally over having a loud car. I want it to be as quiet and as comfortable to cruise in as a new Charger or Ram pickup. I don't want to be heard coming from a mile away anymore, and I don't want every teen in a mustang trying to race at every redlight just because of the exhaust anymore. And I want to be able to drive the car on road trips without getting fatigued from the noise. Not to mention the car is just too damn slow to justify being so stupidly loud. I'm so over it.
So guys, any recommended setups? I'm all ears. Thanks.
Re: Quietest exhaust possible for 440?
[Re: JRs_Charger]
#1571192
01/30/14 02:49 PM
01/30/14 02:49 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
1971 Imperial mufflers used to be highly touted for your purposes. Quiet without too much effect on power.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: JRs_Charger]
#1571193
01/30/14 02:49 PM
01/30/14 02:49 PM
Posts: 5,166 CT
GTX MATT
CT
Any decent turbo muffler should be decently quiet. The quietest though? Some old reverse flow if anyone still makes them.
Walker 21848 used to be the direct replacement for 440 cars, and very quiet. I don't think they make them any more though.
[Re: JohnRR]
#1571195
01/30/14 02:56 PM
01/30/14 02:56 PM
JRs_Charger
Opelika, AL
Lose the flowmasters
Also you need to be realistic , the only way that car will ever be as quiet as a new charger or ram is if it stays parked in your garage and you never start it ...
Haha, understood. Then lets say I want to get it as close as I can to them. Quiet enough at cruising speed where a conversation could be had in the cabin without yelling, or quiet enough that my ears don't ring after a 4 hour drive.
[Re: JRs_Charger]
#1571196
01/30/14 03:00 PM
01/30/14 03:00 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Once you quiet down the exhaust you will hear everything else it was drowning out , rattles under the dash , in the doors , the trunk , and the big one ROAD NOISE ...
Long case Dyno max turbo muffler , a bullet glasspack type muffler as a resonator ... I'm pretty sure Accutate LTD. sells 2.5" stock looking resonator tail pipes ... and replace the H with an X pipe .
[Re: JRs_Charger]
#1571204
01/30/14 10:09 PM
01/30/14 10:09 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
Like a previous poster said, the Walker Quiet Flow 21848 is no longer available. The replacement is a Sound FX 18230. This muffler is in the catalog for the B-Body 440 powered cars. I just picked up a pair for my Newport. They are 2.25" in/out, but they neck down inside the muffler to about 1.75". I'm not too keen on the restriction, so you may want to go with the Dynomax Hemi mufflers.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
[Re: 3hundred]
#1571207
01/31/14 02:15 AM
01/31/14 02:15 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Robert
I bought some Walker Quiet Flow SS mufflers for the Convertible. They are supposed to fit a Imperial. I am going to use them to replace the Super Turbo mufflers that came with the TTI exhaust system, but it is not going to be as easy as I thought. The Imperial sized mufflers are longer than the Super Turbo mufflers, and for them to sit up in the recessed floor pan area, the rear hanger will need to be moved back some and the in and out pipe will be shortened. I am going to weld collector flanges to the muffler outlet and tailpipe for two reasons, the pipes need to be pretty short for the longer muffler, and it will make removing the exhaust easier for transmission service. If the weather is not too bad, and I'm not working weekends I should have it done in a few weeks. This week I'm rebuilding the Dana 60 with 3.54:1 gears. Anyone need some 4.10:1 gears
[Re: JohnRR]
#1571208
02/03/14 12:46 AM
02/03/14 12:46 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Incorrect sir. My stock 66 Coronet 440 383-4 car has stock style dual exhaust with direct replacement mufflers and you can't hear it idling next to a 3G HEMI. With all of the fans, buzzing, clicking, etc. that comes from new cars my stocker sounds like a Swiss watch. To be honest I was amazed to find this out. IMO the wind noise is a bigger deal in these old cars than exhaust note if the exhaust is stock.
[Re: Jeremiah]
#1571209
02/03/14 11:42 AM
02/03/14 11:42 AM
JohnRR
and my followup ...
yes stock replacement, flow restricting mufflers will make it as quiet as a /6 dart
