Big block question #1570950
01/29/14 10:29 PM
01/29/14 10:29 PM
West Michigan
76318dart Offline OP
West Michigan
Hey there everyone. I have a question for my brother. Im not familiar with big blocks that all I have done is smallblocks. My question is what is a good all around intake for a mild built 440?
We got his car with this motor in it. It a 69 fury, big heavy car lol. We put 3.91 gears in it. well as far as we know it has a 509 mp cam and 11:1 pistons and stock heads ( not sure what they are or if they are touched) Right now it has a stock intake on it and feel like its not working well. The carb is a holley 750 3310. The other ? is it has a stock torque converter in it and was wondering what you recommend? I appreciate your help thanks.
76 dart 318 runs 12.9o @ 103 mph with 1.78 60ft.
Re: Big block question [Re: 76318dart] #1570951
01/29/14 10:31 PM
01/29/14 10:31 PM
okla.
sam64 Offline
sam64  Offline
okla.
performer rpm hands down!
Re: Big block question [Re: sam64] #1570952
01/29/14 10:40 PM
01/29/14 10:40 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
3000 stall converter, gears are good. Performer RPM would probably be best in his application, Holley Street Dominator if he doesn't have the hood clearance.
If its a true 11:1 440 with the 509 if its got headers it should rock and roll if its tuned decent. Distributor needs a quick curve and 36-38 degrees of total mechanical advance. It should have been degreed in, but the type of people who put 509 cams in with stock converters usually don't degree their cams.
If it had 2.76s or 2.94s when he bought it I will be you money that the cam is installed dot to dot and around a 112 ICA. If it has stock manifolds still you may be better off with a cam swap to a smaller cam as far as price/ease of getting it running better. If he wants and easy low 13 or high 12 second c body fix the rest and leave the 509 in there. They're old school but MAN do they pull hard for stock headed engines when set up right.
Re: Big block question [Re: GTX MATT] #1570953
01/29/14 11:02 PM
01/29/14 11:02 PM
West Michigan
West Michigan
Okay thanks. It does have Headers and it did have 2.76 gears. I appreciate your response
Re: Big block question [Re: 76318dart] #1570954
01/30/14 12:25 AM
01/30/14 12:25 AM
I wouldn't put any Mopar Purple shaft H.P. brand camshaft in any Mopar V8 under any conditions, degreed or not That being said most Mopar enthusiast(SP?) that buy and use those cams do align the dots and then go from thier Not good All replacement cams should be degreed in and then advanced (per the cam makers suggestions ) to get the best perforamnce out of that cam I'm going to assume that the car has power brakes, yes or no? If so then a lot smaller cam should and probally will work a lot better in that motor in that car
Re: Big block question [Re: Cab_Burge] #1570955
01/30/14 12:49 AM
01/30/14 12:49 AM
dogdays Offline
dogdays  Offline
Cab, you must have read my mind! That 509 cam has no business in a modern engine and certainly not in a C-barge.
Re: Big block question [Re: dogdays] #1570956
01/30/14 01:22 AM
01/30/14 01:22 AM
West Michigan
West Michigan
Well I do agree with you guys but the thing is he doesn't make much money and is still in high school so just trying to improve on what hes got for now. but thanks
Re: Big block question [Re: dogdays] #1570957
01/30/14 03:49 AM
01/30/14 03:49 AM
CT
CT
If you need to fix it for the cheapest cost, the big summit cam is like 120 with lifters. Whatever valve springs work for the 509 would be more than enough for it, assuming someone changed the valve springs. You should probably check pushrod length too. But, people who put 509 cams in C bodies with 2.76s and stock torque converters also don't change pushrods, probably not valve springs either but MAYBE.
Re: Big block question [Re: GTX MATT] #1570958
01/30/14 04:11 AM
01/30/14 04:11 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
HELLO I DON,T AGREE WITH (CAB BURGE) HE IS A CHEVY GUY . THE MOPAR PURPLE SHAFT CAM 509 IS ONE OF THE BEST BIG BLOCK CAMS YOU CAN PUT IN A BIG BLOCK! I HAVE PUT THEM IN A LOT OF BIG BLOCKS AND THEY HAVE GREAT PERFOMANCE .WITH THE MOPAR 509 CAM AND 11,1 PISTONS AND A SET OF 906 HEADS AND THE NEW INDY DUAL PLANE INTAKE AND A HOLLEY 850 CFM CARB .YOU CAN MAKE THAT 440 PUT OUT AROUND 425-475 HP. YOU NEED A 323 OR 355 OR 391 REAR GEAR TO HELP PUT IT TO THE ROAD !!! . A REAL MOPAR MAN !! MY
Re: Big block question [Re: sam64] #1570959
01/30/14 11:54 AM
01/30/14 11:54 AM
gregsdart Offline
gregsdart  Offline
Re: Big block question [Re: gregsdart] #1570960
01/30/14 04:06 PM
01/30/14 04:06 PM
dogdays Offline
dogdays  Offline
If he's stuck with the 509 cam, and believe me I do understand "no budget blues", help it out by advancing the cam 4 or even 6 degrees. That'll close the intake valve earlier and help the bottom end.
One thing that bothers me is "11:1 pistons". What is in there?
That 509 may be a way to bleed off too much compression?!?
R.
Re: Big block question [Re: dogdays] #1570961
01/30/14 05:18 PM
01/30/14 05:18 PM
West Michigan
West Michigan
Honestly we were told that it was 11:1. He can't run pump gas otherwise it runs like crud and spark knocks so I'm sure that it is that much compression or more. I know the when we did a compression check it was like 220ish.
Re: Big block question [Re: 76318dart] #1570962
01/30/14 05:28 PM
01/30/14 05:28 PM
CT
CT
If it really pumped 220 and has a 509 then it has 11:1 or more, and a healthy short block. If thats the case I wouldn't go with a smaller cam!
The converter and intake will hold you back, but that thing should still rip. If it doesn't i'd start looking at the carb and spark curve.
Re: Big block question [Re: GTX MATT] #1570963
01/30/14 05:49 PM
01/30/14 05:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The problem w/a bigger cam to bleed off cyl. pressure is that you`re fighting a heavy car and the vert would have to be a bit looser in my opinion to take advantage and maybe even more gear. Race gas or a stouter/proper cam may get ya there...........
Re: Big block question [Re: 76318dart] #1570964
01/30/14 06:01 PM
01/30/14 06:01 PM
maryland
74yellowduster Offline
maryland
my suggest
~eddy performer rpm intake $200
~quickfuel E85 carb $500 (or get BIGS to build your carb into an E85 carb $200)
~get a fuel pump that will work with E85 $100
~get a 9.5 converter from Dynamic (when you can afford it) $600
~fill up with E85 $50
~make sure nobody is in front of your battleship
~zoom goodbye
Re: Big block question [Re: 74yellowduster] #1570965
01/30/14 06:15 PM
01/30/14 06:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
He`s got a different approach that seems to work well 4 others..........
Re: Big block question [Re: Thumperdart] #1570966
01/30/14 06:25 PM
01/30/14 06:25 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
As CAB pointed out, if the car has power brakes, a different cam should be used. The .509 does not make enough vacuum for the brakes.
Another option could be to install an electric vacuum pump, but that would cost about the same as finding the right cam.
I tried the .509 in my 70 R/T convertible in 1984. Switched back to the .484 cam after I could not bring the car to a stop.
Scott
Re: Big block question [Re: ProStDodge] #1570967
01/30/14 06:33 PM
01/30/14 06:33 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I had a 509 cam in a 360 volare for years with power brakes. Never had a problem with vacuum/brakes, etc.
Re: Big block question [Re: 80fbody] #1570968
01/30/14 07:06 PM
01/30/14 07:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
But that`s only one concern the other is detination w/iron heads at those cranking numbers.
Re: Big block question [Re: 76318dart] #1570969
01/30/14 07:20 PM
01/30/14 07:20 PM
Delray beach, Florida
P
Performance Only Offline
P
If your compression test is accurate, and I do question whether or not it really is that high, check your vacuum at idle and tell us what it is and at what RPM.
machine shop owner and engine builder
