Re: any trick to removing Ball Joints from UCA's? [Re: stumpy] #1570752
01/31/14 01:18 AM
01/31/14 01:18 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Leave the control arms on the car to remove the ball joints or you could end up twisting them out of shape.
Exactly. You need the socket. While you might use a pipe wrench to take the old Ball joint out, you gotta have the socket to put the new one in! Put the arm back in the car BTW before you screw the new ball joint back in.
Astrobuf
Re: any trick to removing Ball Joints from UCA's? [Re: astrobuf] #1570753
01/31/14 04:21 AM
01/31/14 04:21 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The force required to use a breaker bar on the UCA ball joints was going to pull my car off the jack stands. Finally got them off with an impact wrench, but just barely - really needed a bigger, heavier duty impact wrench than my Sears.
Re: any trick to removing Ball Joints from UCA's? [Re: kentj340] #1570754
01/31/14 11:33 AM
01/31/14 11:33 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
3' pipe over breaker bar and still I thought the car was going to come off the lift.
All the while, I kept thinking to myself when it refused to budge, I must be doing this wrong....
Re: any trick to removing Ball Joints from UCA's? [Re: Commando1] #1570755
01/31/14 12:53 PM
01/31/14 12:53 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I doubt my 1/2 Snap On Impact with 150lbs behind it is going to crack them loose...I might have to resort to putting on my 3/4" Sears breaker bar w/ 1/2 adapter and an additional 3' stainless pipe I have for occasions like this.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: any trick to removing Ball Joints from UCA's? [Re: Commando1] #1570756
01/31/14 02:43 PM
01/31/14 02:43 PM
Worcester, Mass
68goldfish Offline
68goldfish  Offline
Worcester, Mass
I also went the pipe and breaker bar route. Would not move at all. I finally decided to try a little PB. It cleaned off all the years of grease and road grime. That is when I found the tack welds! Save yourself a headache and clean them first. Look for welds.
Re: any trick to removing Ball Joints from UCA's? [Re: Pyper70] #1570757
01/31/14 04:28 PM
01/31/14 04:28 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Don't forget to put the Red Bull on them for good luck...
Re: any trick to removing Ball Joints from UCA's? [Re: Pyper70] #1570758
01/31/14 05:19 PM
01/31/14 05:19 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Soak 'em...
A little heat, and a 3/4" impact can be your friend...
They gots to come out...
Re: any trick to removing Ball Joints from UCA's? [Re: RSNOMO] #1570759
01/31/14 09:16 PM
01/31/14 09:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I always use heat, never stripped one this way. My socket is home made.
Re: any trick to removing Ball Joints from UCA's? [Re: justinp61] #1570760
02/09/14 10:48 PM
02/09/14 10:48 PM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
If I'm not reusing I weld a 1" nut to them and use impact to remove them
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: any trick to removing Ball Joints from UCA's? [Re: HUSTLESTUFF] #1570761
02/10/14 02:22 AM
02/10/14 02:22 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Air chisel be careful to not nick the arm though
NS1AAR
