Can someone date this 727 torqueflite #1570595
01/29/14 10:48 AM
01/29/14 10:48 AM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Side rail pan number:H2538334 2824563
Re: Can someone date this 727 torqueflite [Re: johnfin] #1570596
01/29/14 10:52 AM
01/29/14 10:52 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
2824 = April 1, 1969
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Can someone date this 727 torqueflite [Re: 64dodge572] #1570597
01/29/14 11:39 AM
01/29/14 11:39 AM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Well, this transmission came out of a 1966 chrysler 383 and I wanted to see if it is original. I found this chart online and the p/n matches 1966 but I know there is a date code and that really does not match.
Re: Can someone date this 727 torqueflite [Re: johnfin] #1570598
01/29/14 01:27 PM
01/29/14 01:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Anyone know what plant the "H" represents?
2538334 = part number for '66 B & C body 361 & 383
2824563 = ?? (I believe this is a different coding system than the "normal" 8 digit DDDD=date & XXXX=unit number)
Re: Can someone date this 727 torqueflite [Re: 6bblgt] #1570599
01/29/14 01:42 PM
01/29/14 01:42 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I am guessing its the original one then. 66 or 69 doesnt really matter as long as its not 71' and newer, the kits and parts are different.
Re: Can someone date this 727 torqueflite [Re: johnfin] #1570600
01/29/14 03:08 PM
01/29/14 03:08 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
Most plausible explanation for this is the trans was built at a later date as a parts room replacement.
