Re: BB Mopar Crank Drive Mandrels
[Re: Plumb Wired]
#1570255
01/29/14 05:27 PM
01/29/14 05:27 PM
Posts: 3,456 Out West
408strokerdart
Out West
BB ???????
SB isn't the only thing that makes it on my stand...
[Re: 408strokerdart]
#1570256
01/30/14 05:11 PM
01/30/14 05:11 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I just switched from an Aerospace Components drive mandrel to a setup from CV Products. The CV stuff is VERY nice. No more Aerospace Components junk for me.
#1570259
01/30/14 07:24 PM
01/30/14 07:24 PM
an8sec70cuda
The CV products drive setup doesn't use a shaft w/ a keyway either. They use a "pinned" drive setup...it just stacks together and aligns w/ 2 dowel pins. Then one long bolt just holds the stack together.
[Re: an8sec70cuda]
#1570260
01/30/14 07:36 PM
01/30/14 07:36 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Me personally, I HATE the stuff with the long bolt. I want the bolt to hold the balancer only, then the drive centers in the register and uses the 3 balancer bolts to attach. To me this is a much better design, as well as being able to turn the motor either way with the drive
Monte
[Re: Monte_Smith]
#1570261
01/30/14 07:47 PM
01/30/14 07:47 PM
an8sec70cuda
Monte
The long bolt doesn't bolt to the crankshaft. You use a normal short crank to balancer bolt. Then bolt on the crank/drive hub like a normal crank pulley would bolt on. The long bolt just holds the stack of pullies/spacers to the drive hub.
[Re: an8sec70cuda]
#1570262
01/30/14 10:57 PM
01/30/14 10:57 PM
Monte_Smith
North Alabama
Monte
Gotcha.......that's better, but I still prefer a spline drive or similar that will let me rotate the motor with what is on the end of the mandrel.
Monte
[Re: Monte_Smith]
#1570263
01/31/14 12:28 PM
01/31/14 12:28 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
CV Products mandrel I used on one my past R3/W8 builds.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: 1967dartgt]
#1570266
01/31/14 01:03 PM
01/31/14 01:03 PM
an8sec70cuda
Does anyone have a part number for the cv products drive? Looks a lot nicer then my moroso one.
I believe the mopar crank hub is CVD53225 5" pulley CVD30202 3" pulley CVD70204 Can't find the number for the end cap...the pullies and end caps are all universal.
They have all different thicknesses of spacers if you need them. I didn't use any.
[Re: 1967dartgt]
#1570268
01/31/14 01:11 PM
01/31/14 01:11 PM
an8sec70cuda
Where are you guys buying your cv products stuff?
Directly from CV products.
BigCube put some good pics on this thread... https://board.moparts.org/ubbthreads/showflat.php?Number=7907772
