What tires do you use? #1569737
01/27/14 09:49 PM
01/27/14 09:49 PM
In the tower
RonTheAnnouncer Offline OP
In the tower
Another tire post got me wondering about the brands of tires racers are using these days. I see less and less Goodyear and more M/T and Hoosier in my travels. What is your current brand of choice? Feel free to chime in with your reasons!
single choice
Votes accepted starting: 01/27/14 07:48 PM
You must vote before you can view the results of this poll.
Re: What tires do you use? [Re: RonTheAnnouncer] #1569738
01/27/14 09:52 PM
01/27/14 09:52 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
M/T slicks 29.5 10.5 15 and M/T 295 65 15 drag radials
1.39 9.85 - 137 mph
Re: What tires do you use? [Re: Ari440] #1569739
01/27/14 09:56 PM
01/27/14 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run the M/T slicks right now on the race car... I
run the 295/55 ET Streets on the Rampage
Re: What tires do you use? [Re: RonTheAnnouncer] #1569740
01/27/14 09:57 PM
01/27/14 09:57 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I've had better luck with my Hoosiers than I did with the Goodyears or the M&Hs. Mine won't work at all at the track on a Drag Radial - so I run those on the street. The MT ET Street Radials work about 5X better than the "regular" street tires do… just not at the track on my heap. It's just too heavy.
Re: What tires do you use? [Re: Duner] #1569741
01/27/14 11:00 PM
01/27/14 11:00 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Currently on a MT radial, will probably switch to a 26" Hoosier radial for a 26" race. When it saw more "street time" it was always an MT slick
Re: What tires do you use? [Re: SpareParts] #1569742
01/27/14 11:15 PM
01/27/14 11:15 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I usually run M/T but Phoenix had the closest size that the Hoosiers the car had when I bought it.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: What tires do you use? [Re: RonTheAnnouncer] #1569743
01/27/14 11:45 PM
01/27/14 11:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Phoenix user here.Always hook and last a long time. 12.25x 31.25 on 12" wheel.
Nautilus Racing-
Re: What tires do you use? [Re: RonTheAnnouncer] #1569744
01/28/14 12:24 AM
01/28/14 12:24 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't see your list differentiate between DOT and drag-only M/T radials...
Re: What tires do you use? [Re: BradH] #1569745
01/28/14 02:08 AM
01/28/14 02:08 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
M/T 315/60/15 D.R. or M/T 29.5x10.5W's on my Challenger.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What tires do you use? [Re: 6PKRTSE] #1569746
01/28/14 03:45 AM
01/28/14 03:45 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
M/T for the last four years, never looked back. Far superior to the Goodyears I ran before.
Re: What tires do you use? [Re: RonTheAnnouncer] #1569747
01/28/14 06:58 AM
01/28/14 06:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
For the street classes I run the M/T ET Drag Radials. The M/T ET Street is also pretty good. I think the Radial is a bit softer compound than the ET Street?
Re: What tires do you use? [Re: 451Mopar] #1569748
01/28/14 11:04 AM
01/28/14 11:04 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I use Hoosier QTP for my street/strip car. Thinking about trying their radial version of the tire this year.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: What tires do you use? [Re: FlyFish] #1569749
01/28/14 02:10 PM
01/28/14 02:10 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
went from Phoenix to Hoosier then back to Phoenix. my best 60' are with Phoenix
Re: What tires do you use? [Re: RonTheAnnouncer] #1569750
01/28/14 02:44 PM
01/28/14 02:44 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mickey Thompson pro drag radial. Never looking back.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: What tires do you use? [Re: fury62] #1569751
01/28/14 02:50 PM
01/28/14 02:50 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
Phoenix 9.0" x 30.00"
Re: What tires do you use? [Re: 1967dartgt] #1569752
01/28/14 02:54 PM
01/28/14 02:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Heard these are the cats meow.............are they surface sensative like regular radials?
Re: What tires do you use? [Re: Thumperdart] #1569753
01/28/14 03:25 PM
01/28/14 03:25 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Good year 33x14.5
Re: What tires do you use? [Re: RonTheAnnouncer] #1569754
01/28/14 07:22 PM
01/28/14 07:22 PM
Locomotion Offline
Locomotion  Offline
Hoosier 9" lightweight radial slicks. But my class is limited to 9". They are faster than a bias ply, but more sensitive to track conditions. Luckily I am able to race at well prepped tracks on the IHRA circuit as well as occasionally at local bracket tracks.
Re: What tires do you use? [Re: Locomotion] #1569755
01/28/14 07:37 PM
01/28/14 07:37 PM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
Hoosier 33 x 10.5 x 16 on 16 x 16 dbl beadlocs
Re: What tires do you use? [Re: Locomotion] #1569756
01/28/14 09:43 PM
01/28/14 09:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
so are you going to run points at green cove?
