Re: SLICKS....................... [Re: Thumperdart] #1569587
01/28/14 10:38 AM
01/28/14 10:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thumper what type of tire is that you run up front ? Is not a radial is it ? Ron
Re: SLICKS....................... [Re: 383man] #1569588
01/28/14 02:51 PM
01/28/14 02:51 PM
State of confusion
Thumperdart Offline OP
State of confusion
I bought my friends used m/t fronts but in my sig pic those are 165 somethin radials which were WAY heavier..........
Re: SLICKS....................... [Re: Thumperdart] #1569589
01/28/14 02:53 PM
01/28/14 02:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Sticky Mickey's ttf
Re: SLICKS....................... [Re: FastmOp] #1569590
01/29/14 12:28 PM
01/29/14 12:28 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Is there any outlaw tire close to your size?
I put hoosier 26 8.5 on my barracuda and broke my tranny from the *!,€}€ traction.
They hook like he11.
Re: SLICKS....................... [Re: sshemi] #1569591
01/29/14 01:58 PM
01/29/14 01:58 PM
State of confusion
State of confusion
Not sure about an outlaw tire but I`m leaning towards ths M/T stiff sidewall............ Thankxxx all..........
Re: SLICKS....................... [Re: Thumperdart] #1569592
01/30/14 04:15 PM
01/30/14 04:15 PM
norcal
JLaSalle Offline
JLaSalle  Offline
norcal
If you can fit it, check out a phoenix ph362.Its a little bigger all around than the m\t's but has a pretty stiff sidewall, even though its not listed as such.I switched to this tire from the standard m/t and saw nearly .03 reduction in reaction time.I attribute that to the stiffer sidewall.Oh and they hook killer too, a little better than the mickeys, imo.
1967 Coronet R/T
9.83 134mph. 470 cid st.6 heads
10x pro et track champion
Re: SLICKS....................... [Re: JLaSalle] #1569593
01/30/14 04:25 PM
01/30/14 04:25 PM
State of confusion
State of confusion
I`ve heard good things about that brand also.........
Re: SLICKS....................... [Re: Thumperdart] #1569594
01/30/14 06:10 PM
01/30/14 06:10 PM
norcal
JLaSalle Offline
JLaSalle  Offline
norcal
From what I've seen they're the widest tire that is designed for a 10" wheel.11.8" tread width.
1967 Coronet R/T
Re: SLICKS....................... [Re: Thumperdart] #1569595
01/30/14 06:18 PM
01/30/14 06:18 PM
an8sec70cuda Offline
Listen to Monte. M/T 29.5x10.5...get the W if you have room. If not, get the S (stiff sidewall).
CHIP
'06 GMC 2500HD LBZ Duramax
Re: SLICKS....................... [Re: JLaSalle] #1569596
01/30/14 06:27 PM
01/30/14 06:27 PM
State of confusion
State of confusion
Maybe there`s something to that design because years ago the fatter wheel and narrow tire was the sheight.........
Re: SLICKS....................... [Re: an8sec70cuda] #1569597
01/30/14 06:37 PM
01/30/14 06:37 PM
Renton Washington
Triple Threat Offline
Renton Washington
FYI the part numbers are 3062W and 3062S
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: SLICKS....................... [Re: Triple Threat] #1569598
05/15/14 07:41 AM
05/15/14 07:41 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I just ordered the 3062s yesterday hoping to gain a little lip clearance and a little weight use to run the w witch is a good tire but i'm starting to ? the sidewalls on them my slicks or old is there a physical way to check sidewalls on slicks see guys pushing on quarter panels side to side is that the way they check them........
Re: SLICKS....................... [Re: racerx] #1569599
05/15/14 10:29 AM
05/15/14 10:29 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
M/T makes a Pro Drag Radial instead of the 2 full lines all the way around the tire they are staggered around the tire.These are what most of the Fast 275 Drag Radial guys around here are running.
PS Just saw where you said Drag Slicks,if you are going to run off road only drag slicks not DOT,many swear by M/T but I have found GoodYear to be the best at least for my use.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: SLICKS....................... [Re: Monte_Smith] #1569600
05/19/14 01:00 PM
05/19/14 01:00 PM
State of confusion
State of confusion
If you plan to run a true "slick".....and in that size range, there is ONE answer M/T. Put the 29.5 W on it, if it will fit. If not, use the 29.5 S (stiff sidewall). NO company has done more small tire development than M/T
A QTP will NOT 60ft as hard as a real slick, because the carcass is REALLY soft and tends to wad up, to make the treaded tire work better. The BEST 60ft on a treaded tire, will be a drag radial, but they are too hit and miss on a sketchy track and likely useless on the street most of the time
Monte
Kevin from Unlimited hooked me up w/a pair of 29.5 10.5x15-S lightly used slicks yesturday for free from a fellow N.M.C.A. racer who thaught they were done but found leaky shocks. They look damn near new so on they go for a Nova and Vette rematch and two more Chevys after that. Never been on a real slick w/this motor so now we`ll and hope the 8 3/4 holds up...........
Mickey`s website says you can run higher pressures so what are you guys running w/these.............thankxxx..........
Re: SLICKS....................... [Re: Thumperdart] #1569601
05/19/14 01:27 PM
05/19/14 01:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
on the street it wont matter, good luck
Re: SLICKS....................... [Re: Quicktree] #1569602
05/19/14 01:32 PM
05/19/14 01:32 PM
State of confusion
State of confusion
I mean racing pressures................12,13+............
Re: SLICKS....................... [Re: Thumperdart] #1569603
05/19/14 03:49 PM
05/19/14 03:49 PM
Renton Washington
Renton Washington
I ran 12.5# in my 10.5W's
-Dustin
Re: SLICKS....................... [Re: Triple Threat] #1569604
05/19/14 04:10 PM
05/19/14 04:10 PM
State of confusion
State of confusion
Thankxxx.............these are not w`s though.
Re: SLICKS....................... [Re: Thumperdart] #1569605
05/19/14 06:25 PM
05/19/14 06:25 PM
Renton Washington
Renton Washington
Its the same sidewall. Mine were just 1" wider.
-Dustin
Re: SLICKS....................... [Re: Triple Threat] #1569606
05/19/14 06:34 PM
05/19/14 06:34 PM
State of confusion
State of confusion
Cool thankxxx.............My qtp`s like 12.5 slso on the street so far.
