Re: SLICKS.......................
[Re: Thumperdart]
#1569592
01/30/14 04:15 PM
01/30/14 04:15 PM
Posts: 70 norcal
JLaSalle
norcal
If you can fit it, check out a phoenix ph362.Its a little bigger all around than the m\t's but has a pretty stiff sidewall, even though its not listed as such.I switched to this tire from the standard m/t and saw nearly .03 reduction in reaction time.I attribute that to the stiffer sidewall.Oh and they hook killer too, a little better than the mickeys, imo.
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
[Re: Thumperdart]
#1569594
01/30/14 06:10 PM
01/30/14 06:10 PM
Posts: 70 norcal
JLaSalle
norcal
From what I've seen they're the widest tire that is designed for a 10" wheel.11.8" tread width.
[Re: Thumperdart]
#1569595
01/30/14 06:18 PM
01/30/14 06:18 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Listen to Monte. M/T 29.5x10.5...get the W if you have room. If not, get the S (stiff sidewall).
[Re: Triple Threat]
#1569598
05/15/14 07:41 AM
05/15/14 07:41 AM
Posts: 4,085 Mo.
racerx
Mo.
FYI the part numbers are 3062W and 3062S
I just ordered the 3062s yesterday hoping to gain a little lip clearance and a little weight use to run the w witch is a good tire but i'm starting to ? the sidewalls on them my slicks or old is there a physical way to check sidewalls on slicks see guys pushing on quarter panels side to side is that the way they check them........
[Re: racerx]
#1569599
05/15/14 10:29 AM
05/15/14 10:29 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
M/T makes a Pro Drag Radial instead of the 2 full lines all the way around the tire they are staggered around the tire.These are what most of the Fast 275 Drag Radial guys around here are running.
PS Just saw where you said Drag Slicks,if you are going to run off road only drag slicks not DOT,many swear by M/T but I have found GoodYear to be the best at least for my use.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Thumperdart]
#1569601
05/19/14 01:27 PM
05/19/14 01:27 PM
Quicktree
If you plan to run a true "slick".....and in that size range, there is ONE answer M/T. Put the 29.5 W on it, if it will fit. If not, use the 29.5 S (stiff sidewall). NO company has done more small tire development than M/T
A QTP will NOT 60ft as hard as a real slick, because the carcass is REALLY soft and tends to wad up, to make the treaded tire work better. The BEST 60ft on a treaded tire, will be a drag radial, but they are too hit and miss on a sketchy track and likely useless on the street most of the time
Monte
Kevin from Unlimited hooked me up w/a pair of 29.5 10.5x15-S lightly used slicks yesturday for free from a fellow N.M.C.A. racer who thaught they were done but found leaky shocks. They look damn near new so on they go for a Nova and Vette rematch and two more Chevys after that. Never been on a real slick w/this motor so now we`ll and hope the 8 3/4 holds up...........
Mickey`s website says you can run higher pressures so what are you guys running w/these.............thankxxx..........
on the street it wont matter, good luck
