Best bang for the buck / Aluminum RB heads
#1569100
01/26/14 07:21 PM
01/26/14 07:21 PM
Posts: 2,655 western PA
mopar4ya
western PA
Have a friend looking for a set of aluminum heads for his 500 inch RB engine. It has the 440 Source rotating assembly with their Comp Cams Xtreme energy .564 cam. Who has the best bang for the buck head that would be a reliable piece. Are there any issues with using the 440 Source head, or are there better options? Thanks Dan ![](/ubbthreads/images/graemlins/beer.gif)
Re: Best bang for the buck / Aluminum RB heads
[Re: Exit1965]
#1569102
01/26/14 08:47 PM
01/26/14 08:47 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I have the first Stealths.They had a problem with some gaskets hanging in the chamber.That is fixed now.Mine have over 4 years of hard street/strip and no problems.I did change the springs retainers and locks which I would have done even if I had bought Eddys.I needed straight plugs as I run 12.5 domes.Rocky
Chrysler Firepower
[Re: mopar4ya]
#1569103
01/26/14 10:46 PM
01/26/14 10:46 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
I put Indy EZ heads on my stroker and I really like them.If it's going to be a street car I would go with the Edelbrock heads ![](/ubbthreads/images/graemlins/Twocents.gif) Give Nick a call at www.compu-flow.com and let him set them up and check the valve job after you buy them from him. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Sixgun]
#1569106
01/27/14 01:49 AM
01/27/14 01:49 AM
The valve guide material in the Procomps is not good stuff and fails quickly--valve quality is very poor as well. You can order good valves pretty cheap but the stuff that comes in Procomp heads is bottom of the barrel IMO. With the price of Eddys where it is now it is a small jump to Indy. All are TOO high $$ when you see Chevy heads that are great quality for $900 retail.The only diff is Mopar may use a few more lbs of aluminum. I think before long there will be more Mopar choices--there has to be sooner or later. The overseas guys have been making heads for so many outfits now ,I bet it is only a matter of time before we see something new and value priced along with top shelf quality. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: fourgearsavoy]
#1569107
01/27/14 10:54 AM
01/27/14 10:54 AM
therocks
Niles , Ohio
Gus I forgot about telling him to have the valves etc checked.Jerry did all that to my heads.Plus he lapped the valves and opened the heads up a bit.Of course you know he has to have everything perfect.I never used Nick but talked to him a few times.Real nice guy and sells you just what you need.Rocky
Chrysler Firepower
[Re: ]
#1569108
01/27/14 12:47 PM
01/27/14 12:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree, and good advice David. ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
[Re: mopar4ya]
#1569110
01/27/14 07:44 PM
01/27/14 07:44 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Either the 440 Stealth's or Edelbrocks. I'm using Stealths with no problems.
[Re: chrisf]
#1569112
01/27/14 09:26 PM
01/27/14 09:26 PM
DaytonaTurbo
Manitoba, Canada
stealth's are garbage unless you need a wheel chock.
what problems did you have with yours?
[Re: therocks]
#1569113
01/27/14 10:01 PM
01/27/14 10:01 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
I don't think Nick will do Stealths.
[Re: chrisf]
#1569114
01/27/14 10:24 PM
01/27/14 10:24 PM
mopar4ya
western PA
I have owned rpm's, e street and source heads.
e street is the best bang for the buck in my opinion. stealth's are garbage unless you need a wheel chock.
Are you saying this because they have problems or because of how they flow??
Thanks everyone, please keep the comments coming.
[Re: mopar4ya]
#1569116
01/28/14 06:53 AM
01/28/14 06:53 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have an older set of the Stealth heads on the 440/505" stroker, mild street engine. I have had no problems with the heads, but I did some mild porting and valve job to get them to flow around 290 cfm. I think out of the box the flow would be down compared to most other aluminum heads. I used different springs, retainers and locks too. My main reason for using the Stealth heads is their more stock appearance when painted.
I think the Edelbrock heads flow more out of the box, so they may be closer to a ready to bolt on out of the box type of head? These heads do not look stock if it matters.
These stock port size heads are OK for mild performance to around 550 HP (600+ with porting and a roller cam), but with 500"+ strokers the larger max wedge port size is better if your looking for big power numbers. The down side is $1,000+ rocker arm assemblies, and headers for raised exhaust ports.
[Re: 451Mopar]
#1569117
01/28/14 08:54 AM
01/28/14 08:54 AM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
One thing to watch if you go with Eddy RPM's, if you put a heavier spring in them make sure your set has the Ferrea valves!! The no name valves in some of them can't handle higher spring pressures.... You won't like what happens!! ![](/ubbthreads/images/graemlins/eeek.gif) P.S. Replace the locks too...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: QTR MILR]
#1569118
01/28/14 01:35 PM
01/28/14 01:35 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I installed MP 452"s which are Eddy RPM's, built by Edelbrock, with straight plugs. The straight plugs were needed on my 500" stroker because I have Exhaust manifolds, not headers. Checked out at the advertised 84cc's. My Harland Sharp rockers and shafts were a bolt on, as were the rocker covers, intake, and exhaust. I am a happy camper with the quality and performance.
This is the land of the free
because of the brave
