Re: Best bang for the buck / Aluminum RB heads
[Re: ahy]
#1569120
01/29/14 01:58 AM
01/29/14 01:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I couldn't be happier with my stealth heads. While I'd love to have had the budget for Indy's.... I didn't, and was happy to have an option that met my budget. I also like the stock look. Mine are OTB with Comp 10* locks & retainers, and Engle double springs. 4 years now with no issues. Someday, I may upgrade to something like EZ's, but for now I'm happy, and wouldn't hesitate to reccomend them to anyone looking for a budget street / performance head.
[Re: StealthWedge67]
#1569122
01/29/14 03:45 AM
01/29/14 03:45 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
delete
[Re: mopar4ya]
#1569124
01/29/14 12:20 PM
01/29/14 12:20 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
With his engine combo, would he be loosing a lot of top end torque with the stock stealth heads. I know he is looking at what he can afford to do right now, and based on that the stealth's look to be the way to go. I would hate to see him do this if it's going to kill the power potential of the engine. Anyone here have his combo in an engine that has had it on a dyno???. What kind of hp and torque numbers will this make. I know he was hoping to be in the mid to upper 500 hp range.
What does he have for heads now ?? If he has heads that flow between 260- 290 cfm now then he should be looking to step up unless his goal is to fool the non mopar person into thinking he has stock heads .
[Re: 67Satty]
#1569127
01/29/14 02:53 PM
01/29/14 02:53 PM
Posts: 5,167 CT
GTX MATT
CT
If you're going to go to Edelbrocks you may as well go right to the EZs, not much more and you have the same issue with angled plugs. They are probably the best bang for the buck, they just happen to be the most bucks. Usually when people say they want bang for the buck they're more concerned with the bucks than the bang.
That said I've got Stealths on my engine and they looked pretty nice OOTB, CCed all around 80 cc. I needed dual springs so I changed those out. They come with Comp hardware now.
[Re: mopar4ya]
#1569128
01/29/14 03:39 PM
01/29/14 03:39 PM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My combo is 8.97:1 493 with MP509 cam, RPM heads and Holley TBI on a single plane M1. 500 hp@ 5000 and 600 ft/lbs@ 4000. Does it on 87 regular. It carries at least 500 ft/lbs from 2000-5000 but it drops pretty quick from there.
The heads are basically OOTB with the valve job fixed.
Kevin
[Re: GTX MATT]
#1569132
01/30/14 03:26 AM
01/30/14 03:26 AM
383man
Balt. Md
Basically thats why I went with the EZ heads and that Dwayne Porter gave me a great deal and price. Ron
[Re: 383man]
#1569133
01/30/14 12:45 PM
01/30/14 12:45 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Here is a 493 running a Torker II intake, MP 590 cam with prepped Stealth heads flowing,
Lift.........Intake/Exhaust
.100...........75/69 .200..........150/133 .300..........211/176 .400..........254/217 .500..........285/234 .600..........295/262 .700..........297/280
Dyno results,
RPM........TQ/HP
3000......481/275 3200......508/310 3400......546/354 3600......560/384 3800......559/404 4000......552/420 4200......544/435 4400......535/448 4600......543/476 4800......560/512 5000......558/531 5100......549/533 5200......545/539 5300......541/546 5400......532/547 5500......529/553 5600......518/552 5700......510/553 5800......495/547
You sure that exh flow is right ?? I only ask because my EZ heads at .600 were 329 on the intake and 223 on the exh. The last ported RPM head I saw was like 225 at .600. Its just 262 at .600 lift seems like alot on the exh of your head. Dont mean it to be smart just want to be sure thats correct. Ron
Yep, positive. That's with a 2" diameter tube 2-1/2" long. The Indy EZ exhaust? 290 cfm @ .600" & 308 cfm @ .700". Been there, done that.
[Re: 80fbody]
#1569135
01/30/14 06:03 PM
01/30/14 06:03 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You guys are way to hung up on exhaust flow. Some guys use a tube on the exhaust to inflate their exhaust flow numbers by 20-30 or even more CFM. To quote one of the better head guys out today (Darrin Morgan). Exhaust port airspeed is more important that exhaust port cfm. Aim for 300+ FPS and the exhaust WILL get out. You will hear a bad exhaust port on a flowbench just like you will hear a bad intake port. Its all about port shape.
[Re: pittsburghracer]
#1569137
01/30/14 11:14 PM
01/30/14 11:14 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
I apologize for being inflationary and not up to snuff as to how the big boys do it. In my defense, every engine we run on our dyno and every engine in every one of our cars has some kind of tube connected to every exhaust port.
Do any of you run straight out of the heads on your cars with no other exhaust system?
I'd like to say more, but inflammatory along with inflationary would be infra dignitatem.
