What Gauge Sheet Metal? #1568498
01/25/14 01:05 PM
01/25/14 01:05 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Doing some patch work on the engine compartment and need to patch some areas. What gauge sheet metal would you use?
thx
[img] [/img]
Re: What Gauge Sheet Metal? [Re: clonestocker] #1568499
01/25/14 02:27 PM
01/25/14 02:27 PM
Out West
408strokerdart Offline
Out West
22Ga.
Re: What Gauge Sheet Metal? [Re: 408strokerdart] #1568500
01/26/14 02:32 AM
01/26/14 02:32 AM
20ga
Re: What Gauge Sheet Metal? [Re: clonestocker] #1568501
01/26/14 04:13 AM
01/26/14 04:13 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
The lightest you can weld in without warping too badly.
Re: What Gauge Sheet Metal? [Re: 408strokerdart] #1568502
01/26/14 03:30 PM
01/26/14 03:30 PM
Out West
Out West
22Ga.
Actually 21Ga. is perfect, but you can't find that anywhere. I err on the side of thinner so I can skim coat it and finish it. You can use the 20Ga. if you want it slightly thicker than factory metal.
