Re: 1969 Coronet R/T referance phots needed [Re: AZ_A12_BEE] #1568323
01/27/14 10:24 PM
01/27/14 10:24 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Air grabber #2
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 1969 Coronet R/T referance phots needed [Re: AZ_A12_BEE] #1568324
01/27/14 10:27 PM
01/27/14 10:27 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Fender #1
Re: 1969 Coronet R/T referance phots needed [Re: AZ_A12_BEE] #1568325
01/27/14 10:28 PM
01/27/14 10:28 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Fender #2
Re: 1969 Coronet R/T referance phots needed [Re: AZ_A12_BEE] #1568326
01/27/14 10:29 PM
01/27/14 10:29 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Fender #3
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568327
01/27/14 10:50 PM
01/27/14 10:50 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I asked on the A12 site. It serms that you could order the A01 light package with the N96 option...just not the L31 fender mounted turn signals by themselves. If you have a map light, trunk light and ignition delay, you would have fender turn signals too.
Re: 1969 Coronet R/T referance phots needed [Re: RoadRunnerJD] #1568328
01/27/14 11:06 PM
01/27/14 11:06 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
M Code Bees do not code N96 so that's kind of a non starter.
L31 IS a valid option on A12 Bees.
L31 is not part of A01. It's a separate option.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1969 Coronet R/T referance phots needed [Re: RoadRunnerJD] #1568329
01/27/14 11:22 PM
01/27/14 11:22 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
John, I think a glove box light came with the A01 package and a console compartment light if you had a console(?)
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568330
01/27/14 11:29 PM
01/27/14 11:29 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
Re: 1969 Coronet R/T referance phots needed [Re: 69CoronetRT] #1568331
01/28/14 12:57 AM
01/28/14 12:57 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Yep, my car has N96 and A01.
Re: 1969 Coronet R/T referance phots needed [Re: Ludington1] #1568332
01/28/14 02:25 AM
01/28/14 02:25 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Pretty sure console light came with the console regardless if you had A01 or not.
Seeking:
Re: 1969 Coronet R/T referance phots needed [Re: 69CoronetRT] #1568333
01/28/14 02:38 AM
01/28/14 02:38 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I ordered the A01 light package on my '69 road runner with Air Grabber, and a console and I know it had the ash tray, glove box, map light, trunk light, *ignition key delay, fender top bullets, but I don't remember if the console compartment had a small light inside? probably not. (I know the left and right side lights are standard on all of those console...and nice mood lighting touch BTW ).
Can't see any other reason than the right N96 hood scoop on the Dodge blocking the fener light because my Air Grabber road runner had them (my rr) BUTT you can't see it in this photo because someone's BUTT is blocking it here
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568334
01/28/14 02:46 AM
01/28/14 02:46 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
No A01 light package on my '69 GTX but the console lights.
The first few times I got into my '68 road runner at night I had trouble finding the ignition switch because I was so used to having the time delay ignition light Then I started to leave the door open until I put the key into the ignition and that used to confuse my wife and son "What are you doing, close the door it's cold and the exhaust smells"
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568335
01/28/14 02:55 AM
01/28/14 02:55 AM
AZ A12 Bee, thanks a lot for the detailed photos. I am going to try and print them in detail and hand them right to my bodyman.
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568336
01/28/14 02:57 AM
01/28/14 02:57 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Just this, I didn't believe it so I put a socket on the fender and sat in the driver's seat and couldn't see it over the scoop from the driving position.
Re: 1969 Coronet R/T referance phots needed [Re: ] #1568337
01/28/14 01:43 PM
01/28/14 01:43 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
PM me if you need anything else
Re: 1969 Coronet R/T referance phots needed [Re: Ludington1] #1568338
01/28/14 02:48 PM
01/28/14 02:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If you had the Ramcharger hood scoops they should have just made the option available at half price ($5.40) then there wouldn't have been any justified complaints of not being able to see it, "Sorry sir we understand that you can't see it and that's the reason we didn't charge you for it"
Re: 1969 Coronet R/T referance phots needed [Re: A12] #1568339
01/28/14 02:56 PM
01/28/14 02:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
They deleted them on Challengers too until 73 I think. My car has them and you can't see the PS one over the Rallye hood.
