Re: Hemi ID Question
[Re: 68jim]
#1568224
01/26/14 06:45 PM
01/26/14 06:45 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I agree on the not painted part.
I also agree, but I am leaving the door open for other possibilities. I've seen quite a few NOS blocks (so far all bare) but have seen a fair number of warranty installed examples also, and some offer clues pointing towards some of them possibly being factory painted. Hopefully we as a group can keep investigating and add to the details we know about these.
[Re: ScottSmith_Harms]
#1568225
01/26/14 10:23 PM
01/26/14 10:23 PM
Posts: 4,788 Ontario, Canada
mccannix
Ontario, Canada
Scott Wouldn't it make sense for someone to paint an engine just before installing. If I were putting an over the counter block in back in the day, I would certainly have painted it. I cant see the factory doing it..but then I wasn't there either. The picture of your painted engine with the blue tag shows the rivet just resting against the tag like someone added it. Those tags have always been available for sale if you look hard enough. I know of two old school buses with about 15 'over the counter' blocks in their old wooden crates... 273, 318, 360, 361, 400's and none were painted. Nor were the 340 or 440's that are gone now, painted.
[Re: mccannix]
#1568226
01/27/14 02:56 AM
01/27/14 02:56 AM
Posts: 5,123 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Never seen a bare block or short block that was bought from a Dealership ever having paint on it. The Hemi Short Block that was stolen from a person on Moparts and made its rounds from person to person then showed up on a thread on moparts was not painted just like the one above. I have had a few 440 bare blocks counter bought and all were not painted. The Hemi over the counter blocks I have owned were all used before I got them but I bought them completely without paint because they were ready to be assembled. One other thing, at one time when I built a motor I could not get Hemi Street Orange from the Dealership or any other place. This was around late 70s. I ended up using Plastikote Orange that is close in color back then. I have no idea why no one had Street Hemi Orange at the Dealerships.
1971 HEMI E BODY REGISTRY
[Re: MarkMcDonald]
#1568228
01/28/14 06:08 PM
01/28/14 06:08 PM
Posts: 1,672 Virginia
HemiStan
Virginia
I have been reading this thread as well as this one: 70 440 Warranty Block I have this 1970 Hemi block with no VIN stamping. It does have the WT on the front pad. I can find no evidence of a hole in the side of the block for a rivet retaining a metal tag. As you can see from the back of the engine, there appears to be some of the correct Hemi Orange paint remaining. The rest of the orange paint seems to have been painted later and with the incorrect color. I don't know if these pictures add anything to this thread but they may provide a bit more information regarding OTC and warranty replacement blocks. From looking at the pictures, does anyone have anything that they could share regarding this block? Thanks. Stan
[Re: HemiStan]
#1568233
01/28/14 06:13 PM
01/28/14 06:13 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Thanks.
Stan
Stan that tag would only be affixed to an engine that was an assembly , I wouldn't expect to find the tag on a bare block that went over the counter .
[Re: HemiStan]
#1568238
01/29/14 12:25 PM
01/29/14 12:25 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
Does yours have a "B" stamped on the front pad?
Stan,
Aside from the usual WT it also has two "B"s stamped on the pad.
[Re: hemicar1971]
#1568239
01/29/14 10:40 PM
01/29/14 10:40 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Mind your Ps and Qs. If I can remember correctly a block bore size can be 70th over stock in Super Stock. Can not remember the crank but it is something like 3.85. Wish I had an old NHRA book to study again. Going only by my memory and it is getting older and older, and I will type this like a question. Did Chrysler not put different letters on the side of the blocks to signify what piston went into each bore when assembling a Hemi at the factory. I thought I remember BCDEF piston sizes. So the Ps and Qs would be for another type of Chrysler description of a bore size of a Hemi Block.
NHRA allows OEM stroke plus .015, or 3.75 + .015 = 3.765.
The extra .015 gives about 1.75 cu in. Every bit helps in SS.
