Re: Does the 1st Gen Dakota (1992) have a speed governor?
[Re: hp383]
#1568097
01/24/14 07:43 PM
01/24/14 07:43 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Ive never heard of 1. I believe the limiting factor comes from being out of HP on the top end.
I am truckless..
[Re: Golden-Arm]
#1568099
01/24/14 10:50 PM
01/24/14 10:50 PM
Posts: 15,487 Florida
scratchnfotraction
my 92 dak 5.2 ran out of steam at 115mph. 4th gear,TC locked up, down hill with tailwind. my buddys 2000 Toyota tundra with 265 HP v-8 shuts down at 107mph and holds that up hill down hiil with or without tailwind. this is how I know the dak goes to 115mph it out runs the toyo on topend.
[Re: Golden-Arm]
#1568101
01/25/14 01:17 AM
01/25/14 01:17 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
[Re: mopwrd340]
#1568103
01/25/14 11:41 AM
01/25/14 11:41 AM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
I would not be surprised if there was, Chrysler started putting them in the turbo cars as far back as 87 or 88 for liability reasons. Usually its tied to the speed rating of the tires that were on the vehicle when sold new.
I think it was 118 on the average turbo car, the Shelby Z's had Z rated tires and it was set to 256 mph in the code. The code does not let you shut it off, just set to the highest set point.
A cheap "fix" was to place a toggle switch in the speed sensor circuit and just break it as needed, not sure if that is practical on a Dakota or not with computer controlled overdrive.
"I think its got a hemi"
[Re: stumpy]
#1568105
01/25/14 04:58 PM
01/25/14 04:58 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I read that you can turn the key to the start position when you reach the governed speed and it would disable the governor as long as you held the key there..
I saw something about that on a Dakota Forum yesterday, and that just doesn't sound like a good idea.
Mine does indead have a speed limiter, it cuts out right near or at 115mph. I was not focused on the speedo, but rather the road. I know it climbed over 110mph, but when it cut I looked down and the needle was dropping from 115mph.
The RPM's were not over 4K.
I dont need to bypass the speed limiter, Im not going to be driving that fast again anytime soon. It was a smooth and thankfully uneventful trip to 115mph, but that truck is just so tiny that I dont like it, things move past the window too quickly.
I just recently had the rear swapped to a 3.91 8-3/4 and BOY HOWDY, did that wake up that 5.2 Magnum!!!
I cant wait to take it to the local 1/8mi track this spring for the fun runs.
My next step is to finally install the Jet performance stage II module now that I have my timing issues sorted out (needed a new distributor drive gear and bronze bushing). I also have my Accel Super coil, which oddly has a Caution Death warning on it. (Never seen a death warning on a coil before, Caution shock risk sure, but death?)
Hopefully now it will give me many years, and miles of trouble free service.
It better after all the new parts. New front drilled slotted rotors, wheel bearings, rack and pinion, tie rods, new brakes and hydraulics all around, new speed rated tires, new rear end, new transmission, well maintained engine, had plenum gasket fixed, new timing chain, waterpump, alternator, tuneup, distributor, lots of electrical sensor parts other misc dohicky stuff.
I sure hope the little truck appreciates all Ive done to keep it out of the crusher.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1568106
01/25/14 05:10 PM
01/25/14 05:10 PM
Posts: 5,025 new jersey usa
11secdart
new jersey usa
I had one of those Accel coils on my 92 D150 5.2 Magnum, last year after chasing a miss and hard start problem for a few months I traced it to the Accel coil going bad. I put the stock coil back in and its been fine ever since. I also have a Mopar Hi-Performance computer which may move the rev limit up.
[Re: 11secdart]
#1568107
01/25/14 05:25 PM
01/25/14 05:25 PM
hp383
State of Confusion
great... I will give mine a try, but as always I keep a spare coil, and CPS in the truck from prior experiences...
[Re: hp383]
#1568108
01/25/14 06:02 PM
01/25/14 06:02 PM
Posts: 18,432 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I'm curious if the 1992 Dakota with the 5.2 magnum has a top speed governor?
I don't know about top speed but they do have a rpm limiter which could relate to top speed if it had enough guts to push it that far.
