Re: 3.54 gear
[Re: Sport440]
#1567995
01/25/14 02:05 AM
01/25/14 02:05 AM
Posts: 43,741 Bend,OR USA
Cab_Burge
With the 512 and combo, probably 0, you may even be faster with the 3.54.
Since you want to drive it Alot, Absolutely keep the 3.54 gears.
I treid from 3.73 to 4.30 in my Duster with a pump gas 518 C.I. low deck stroker, it didn't make any noticeable differences at the track, other than spending a long time in high gear with the lower gears
