Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567831
01/28/14 06:42 PM
01/28/14 06:42 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Have you inspected your intake at that corner to make sure that there are no cracks around that mounting stud/threaded hole?
Re: Who makes the best carburetor base gaskets? [Re: YO7_A66] #1567832
01/28/14 07:47 PM
01/28/14 07:47 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
ya I don't believe it is the intake manifold. There are no cracks in it anywhere. I truly believe the problem was in the spacer. I must have over tightend my edelbrock carburetor on top of the spacer and warped it. Hopefully it didn't d o any damage to my quick fuel. I wouldn't think so since I have never tightend the carburetor nuts tighter then what quick fuels spec is which is 8 ft lbs. And it hasn't had a whole lot of miles put on it. I'm pulling the carburetor off here in about an hour. and i'll check it out.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567833
01/28/14 09:08 PM
01/28/14 09:08 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
well pulled the carburetor off and I don't see any cracks in the base plate and I held my ruler across it on its edge and I couldn't slip the feeler gauge under the ruler anywhere. I pulled my current 1 inch 4 hole spacer off that I was running which was having trouble sealing in the passenger front corner. I had a 1/2 4 hole spacer that was brand new and I decided to sand it on flat glass first and even being bran new it wasn't true and flat.
So the 1 inch 4 hole spacer I am starting on now, I'm going to sand it the same way I did the other one and it should solve my problem of not being able to seal a gasket in the front left corner.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567834
01/28/14 09:18 PM
01/28/14 09:18 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
there are a lot of spots on this 1 inch phenolic spacer that aren't sanding, which tells me it wasn't really close to being perfectly flat.
Is torqueing my carburetor stud nuts to 8 ft lbs too much? Because that's what quick fuel says to torque them at.
Re: Who makes the best carburetor base gaskets? [Re: pjc360] #1567835
01/28/14 09:30 PM
01/28/14 09:30 PM
8 ft lbs is fine crisscrossing in even steps. as long as the carb & spacer bolt holes dont hit the bolts & the carb/spacer are seated all the way down & I know you're aware/past that (potential problem).
Re: Who makes the best carburetor base gaskets? [Re: RapidRobert] #1567836
01/28/14 09:47 PM
01/28/14 09:47 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Don't forget to check the intake manifold for flat also.
