Re: Who makes the best carburetor base gaskets?
[Re: pjc360]
#1567831
01/28/14 06:42 PM
01/28/14 06:42 PM
Posts: 5,446 Indiana
YO7_A66
Indiana
Have you inspected your intake at that corner to make sure that there are no cracks around that mounting stud/threaded hole?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: pjc360]
#1567835
01/28/14 09:30 PM
01/28/14 09:30 PM
RapidRobert
8 ft lbs is fine crisscrossing in even steps. as long as the carb & spacer bolt holes dont hit the bolts & the carb/spacer are seated all the way down & I know you're aware/past that (potential problem).
