Just be the faster car then you don't have to worry about all that turning around and crap.
Well thats easier said than done. He races against dragsters too...
Casey
Yeah I know, pick your class and build your car to run at the bottom of it. I won a lot of races and a track championship running in the 10 flat and up foot brake class.
