Re: Questions going from M1 to Victor...
#15693
07/02/05 10:29 AM
07/02/05 10:29 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Greg - I may have to work my intake swap around the long awaited trip to the body shop! Your car looks awesome! Love the low profile scoop...nicely done.
2 kids and a dog
[Re: cudadon]
#15695
07/02/05 03:11 PM
07/02/05 03:11 PM
My car idles just fine once it's warmed up. I spent a good amount of time tuning the carb, including chassis dyno time. you can find engine specs here: Bigblockscamp.com
[Re: cudadon]
#15697
07/03/05 11:43 AM
07/03/05 11:43 AM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
Wouldnt an Edelbrock Performer RPM be better for that heavy car?
Thordur Ingvarsson, Reykjavik Iceland
1970 Dodge Challenger R/T 440 sixpack Shaker(sold)
1971 Plymouth Cuda pro-street project
2007 YAMAHA YZF R1 189 HP
2007 YAMAHA FZ1 SA 150 HP
2003 Mercedes Benz E-200 Kompressor 163 HP
toti62@internet.is
[Re: cudadon]
#15698
07/22/05 11:19 AM
07/22/05 11:19 AM
Posts: 12,423 Warren, MI
71TA
Warren, MI
Gregg, mine gets better when it warms also. Until it warms what does yours do? What carb and tuning did you do? Thanks, Don
My (470") with Victor chugs a bit until warmmed up. After hot it runs great.
[Re: jamesc]
#15699
07/22/05 03:09 PM
07/22/05 03:09 PM
BradH
it would be nice to know what if any difference the clean up made...
Those were my intakes (I had both an unmodified Victor and the one on which I did the plenum mods) and the difference when dyno tested on Dwayne Porter's dyno was approx. 10 HP in favor of the modified piece.
[Re: TonyS451]
#15700
07/22/05 04:38 PM
07/22/05 04:38 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Did a back to back test last fall between M1 Dominator and Victor with 4150 base and an adapter. Did two baselines then made the switch. Car was ( at that time) 71 Cuda,440,3100# and saw approx .070 difference ( better with Victor). I cant say that the Victor or the adapter made the difference. Both these intakes were bone stock untouched. I did think the Victor ran smoother however, but didnt equate to any giant ET. I suspect the extra velocity and plenum area made the biggest difference.
RIP Monte Smith
[Re: cudadon]
#15701
07/22/05 05:27 PM
07/22/05 05:27 PM
When it's cold, it acts like a cold engine with no choke, no big deal. I had to re-jet, reduce the main air bleed size, reduce the idle feed restriction size, and open the power valve channel restrictions. Doing any of this without testing the A/F ratio is like shooting in the dark.
[Re: 340king]
#15703
07/22/05 07:19 PM
07/22/05 07:19 PM
CompWedgeEngines
Syracuse,NY
Yes I realize that. Thats why I mentioned they were stock untouched. This way it was a true unbiased comparison. I also believe that I could have made a difference with a port match, but I was only comparing them in their "as is" states. We knew we'd be changing engines in that car, but I will do a port match on it in the next car and document the change.
RIP Monte Smith
