Alternator guage on LRT caught fire!
#1567066
01/22/14 03:21 PM
01/22/14 03:21 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
I have a 78 Little Red Express Truck. The truck has been sitting for ten years. I just replaced the exhaust system,starter,battery cables,and brake calipers. I am trying to get it back on the road this year. After I changed out the plugs and changed the oil,I was trying to tune the carb,when I saw smoke coming from behind the dash. I shut the truck off and disconnected the battery. I had to reach up behind the alternator guage and pull the smoldering insulation out before the truck caught fire. The wires to the guage were red hot. I also noticed one of the wires to the voltage regulator had melted as well. What is the best way to go about fixing this issue? Any help would be greatly appreciated. Thanks Pete.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
Re: Alternator guage on LRT caught fire!
[Re: Polarapete]
#1567068
01/22/14 04:16 PM
01/22/14 04:16 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Common problem on those years.I had 5 of them and eliminated the amp gauge on all.The gauge starts to melt then shorts.I simply disconnected them and used a small screw and nut to hold them together.Tape real good and install a volt meter.Last truck I had went 6 years like that.Rocky
Chrysler Firepower
[Re: therocks]
#1567069
01/22/14 04:51 PM
01/22/14 04:51 PM
chargervert
I have owned Mopars for 30 years,and I never had this issue. I did buy a car that had a dash fire before,and this was probably the cause. I will connect the wires as you said Rocky. I have a factory guage pod with the voltmeter and vacuum guages. I do not have the wiring for the guage. How would I wire up the voltmeter guage?
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: stumpy]
#1567071
01/22/14 05:15 PM
01/22/14 05:15 PM
chargervert
Thanks Stumpy. I will wire it like that. I wondered if using the factory guage could be wired right into the harness. The optional guage pod must have a plug in somewhere on the harness.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#1567072
01/22/14 07:07 PM
01/22/14 07:07 PM
Posts: 10,200 Someplace you aren't
SomeCarGuy
I just take one lead from the amp gauge and put it on the other terminal. Some hamfist put together the ends on a car I bought with a screw and tape. Ended up arcing under the dash. Not a fun experience.
I want my fair share
[Re: stumpy]
#1567073
01/22/14 07:20 PM
01/22/14 07:20 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
Volt meter is 12v key on and a ground.
You can disassemble the original amp gauge & a voltmeter & put the voltmeter on that space using the original face
[Re: chargervert]
#1567076
01/23/14 06:06 AM
01/23/14 06:06 AM
Posts: 3,265 Pyeongtaek, South Korea
69HemiGTX
This is the Achilles heel of the 72-80 truck gauges. The way Ma did it, 100% of the battery power is routed through the gauge, making fires quite common. Tim linked to what seems to be the most popular tech article about it and how to fix it.
OIF V and OEF X veteran and proud of it!
[Re: retiredguy]
#1567078
01/24/14 10:26 AM
01/24/14 10:26 AM
therocks
Niles , Ohio
Larry those dont look bad at all.My one would die when I was plowing and loose all power.Pulled the gauge and it was totally melted.Im suprised it didnt burn.It was one of the first ones I had.I installed my volt gauges in the part that goes to the DS of the dash.I wasnt worried about correct looks.I do have a NOS harness at the house for a RC.I dont know if its for the volt meter though.It supposedly is for the dash with all the fancy gauges with tach etc.Rocky
Chrysler Firepower
[Re: chargervert]
#1567080
01/24/14 12:41 PM
01/24/14 12:41 PM
Posts: 1,357 central Florida
VL21
central Florida
Important note, I am an electrical idiot ...
Because I am an idiot, I have to ask ...was this problem solved on the '81 and newer trucks?
My '85 moves such a small amount that I am not sure that it is even moving, and previous 88 and 92 trucks as I remember were the same.
I DID have a 72, 74, and 76, and none of them had this problem ... of course that WAS in 73,74, and 76 ...
It takes gasoline to interest me.
[Re: VL21]
#1567081
01/25/14 01:09 AM
01/25/14 01:09 AM
Posts: 18,408 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You do not have the old inductive style. You can remove your cluster and the truck will still work just fine. The newer style uses a shunt style set up and just senses current which makes it operate.
[Re: NITROUSN]
#1567082
01/25/14 03:10 AM
01/25/14 03:10 AM
VL21
central Florida
Good to know,I will sleep better tonight. Thanks
