Page 2 of 3 1 2 3
Re: Cowl Hood [Re: 440W8 Duster] #1565801
01/20/14 06:28 PM
01/20/14 06:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Another thing to think about... when you are traveling
down the road in a rain... which way do the rain drops
go... if up then its not gonna put air into the back
of the cowl... the cowl itself is blocking the upward
flow if its close enough to give the low pressure
area needed at the back of it... so between the low
pressure created from the intake/pistons and the
cowl close enough it should get good flow.... I was
gonna do a test on my car(P-Body) and a guy that was
running a cowl.. we both had similar speeds but he
blew up the engine and I never got the chance
Re: Cowl Hood [Re: bad1970dust] #1565802
01/20/14 07:09 PM
01/20/14 07:09 PM
San Antonio,TX
440W8 Duster Offline OP
San Antonio,TX
my 71 with cowl
Is that in Humboldt Ia?
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Cowl Hood [Re: MR_P_BODY] #1565803
01/20/14 09:25 PM
01/20/14 09:25 PM
K
KOS Offline
KOS  Offline
K
My car hates the cowl hood
I run a 5inch glasstek similar to Johns.I have tried 3 to 4 air pans,blocking this and that and different carb spacers and it dirty's the plugs after one run.
I also run a max effort carb that's 2.20 bore that's made for the most air you can throw at it.
Chris how does Butch Kemp run so quick with a cowl hood on the Mustang and its sealed to the hood
You need to look at the distance from the windshield..
close(about 1" to max 2")... this is mine but its
no A-body... I set this up up so I could hinge it
but I am thinking about making a slider on the back
opening to get it close for racing
my car hates it also.....glasstek 6"trimmed to 1.5" off windsheild as per instruction.factory 6pak hood worth solid tenth to 2 over the cowl.tried it with no hood also and went faster by about the same as 6pak through an aircleaner though in a dart.
Re: Cowl Hood [Re: KOS] #1565804
01/20/14 09:35 PM
01/20/14 09:35 PM
Out West
408strokerdart Offline
Out West
Does pro stock allow cowl hood scoops? If they do, why doesn't everyone run one?
Personally, I am convinced there is no substitution for clean/cool air.
Re: Cowl Hood [Re: KOS] #1565805
01/20/14 10:03 PM
01/20/14 10:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Now I`m definately gonna make my 6-pack scoop work..............
Re: Cowl Hood [Re: headhunter] #1565806
01/20/14 10:37 PM
01/20/14 10:37 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
what about both
Now that this car is a streeter,want to sell the hood or trade lmk.
Thats the set up i want
Re: Cowl Hood [Re: 408strokerdart] #1565807
01/20/14 11:07 PM
01/20/14 11:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pro Sock says it HAS to be front facing
EDIT
I agree with you...I like my scoop facing forward
and up in the clean air stream
Re: Cowl Hood [Re: MR_P_BODY] #1565808
01/21/14 01:55 AM
01/21/14 01:55 AM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
My 8 inch glasstek
Re: Cowl Hood [Re: mistress] #1565809
01/21/14 02:10 AM
01/21/14 02:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My 8 inch glasstek
Is your scoop sealed... where is the seal at in relation
to the hood itself... also where are the carbs in the
scoop... how far from the top of the carbs to the scoop
Re: Cowl Hood [Re: MR_P_BODY] #1565810
01/21/14 11:13 AM
01/21/14 11:13 AM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
My 8 inch glasstek
Carbs are pretty much center of scoop and the front carb is about 3 inches from scoop, rear carb a little more clearance. There is about an inch and half clearance to windshield and carbs are not sealed to hood.
Re: Cowl Hood [Re: mistress] #1565811
01/21/14 12:10 PM
01/21/14 12:10 PM
San Antonio,TX
San Antonio,TX
My 8 inch glasstek
So does it run quicker sealed to the hood or not sealed?
70 Duster W8 motor.
@3170 lbs.
Re: Cowl Hood [Re: 440W8 Duster] #1565812
01/21/14 12:12 PM
01/21/14 12:12 PM
San Antonio,TX
San Antonio,TX
On another note. SS/AH do they seal their carbs or not to the scoop?
70 Duster W8 motor.
@3170 lbs.
Re: Cowl Hood [Re: 440W8 Duster] #1565813
01/21/14 12:24 PM
01/21/14 12:24 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
My 8 inch glasstek
I had a smaller cowl hood with a single carb and sealed it to hood and didn't make a bit of difference, now with the tunnel ram and two 4's i didn't mess with trying to seal the carbs on this hood.
Re: Cowl Hood [Re: mistress] #1565814
01/21/14 12:28 PM
01/21/14 12:28 PM
San Antonio,TX
San Antonio,TX
My 8 inch glasstek
Do you have a SB or BB?
70 Duster W8 motor.
@3170 lbs.
Re: Cowl Hood [Re: 440W8 Duster] #1565815
01/21/14 01:14 PM
01/21/14 01:14 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
FWIW...I used to run a six pack hood on my cuda. It ran about a tenth quicker and 1 mph faster sealed than it did unsealed.
I switched to a 5" cowl hood, unsealed, and it ran the same as the sealed six pack hood.
This was on a combo that I'd run for years.
I have experimented w/ sealing the cowl hood to the carb but haven't seen anything really.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Cowl Hood [Re: 440W8 Duster] #1565816
01/21/14 01:50 PM
01/21/14 01:50 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
My 8 inch glasstek
BB
Re: Cowl Hood [Re: 440W8 Duster] #1565817
01/21/14 02:00 PM
01/21/14 02:00 PM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
my 71 with cowl
Yes our local skating rink lol
Re: Cowl Hood [Re: mistress] #1565818
01/21/14 07:13 PM
01/21/14 07:13 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
My 8 inch glasstek
Can you run air cleaners with that scoop? i mean is there enough room for them? i am building a 73 duster and am going to have to find a 7-8 inch tall hood scoop for my car.I am also running a tunnel-ram on RB 440. could you post a pic of the scoop from the drivers seat? if not no big deal/ thanks mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Cowl Hood [Re: 440W8 Duster] #1565819
01/21/14 08:50 PM
01/21/14 08:50 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
If you go down to the US Nationals and look at all the hemi cars, not one of them that I saw had there hoods sealed to the carbs.
Re: Cowl Hood [Re: OUTLAWSSAA] #1565820
01/21/14 09:30 PM
01/21/14 09:30 PM
San Antonio,TX
San Antonio,TX
Ok so that means you or the SS/AH make better power without a sealed hood or they just work better that way.
70 Duster W8 motor.
@3170 lbs.
Page 2 of 3 1 2 3
