Sheet metal cutting #1565006
01/18/14 12:33 PM
01/18/14 12:33 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
What is the best way to cut the two 4" scoop holes in a Demon hood? Too big for a hole saw and I'm affraid a jigsaw will be a rough cut even with a fine blade.
Re: Sheet metal cutting [Re: GKMOPAR] #1565007
01/18/14 12:59 PM
01/18/14 12:59 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I cut holes under the twin scoops on my duster. I was able to find and use a 4" hole saw from potters. Then cleaned up the edges with a carbide bit. Then used the factory rubbers.
Matt
Re: Sheet metal cutting [Re: GKMOPAR] #1565008
01/18/14 01:02 PM
01/18/14 01:02 PM
I used a sabersaw with a fine blade (as you described) to cut a circular piece of metal out of the side of a washing machine sitting in the back yard for an anticav plate. The cut was nice & smooth & I dont have much metal working experience. I was surprised that it came out that nice. Go slow & keep your eye on the blade, keeping it on your circle
Re: Sheet metal cutting [Re: RapidRobert] #1565009
01/18/14 02:01 PM
01/18/14 02:01 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
a electric or pneumatic 4 inch cut off tool
Re: Sheet metal cutting [Re: GKMOPAR] #1565010
01/18/14 04:07 PM
01/18/14 04:07 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Well you can hack your way through the hood with hole saws, jig saws, etc, or you can do it professionally, find someone that does Industrial Electrical work to borrow a Greenlee set, or perhaps there's an Agricultural/Industrial tool rental store in your neck of the woods, use a Greenlee hyd. punch/knock out set, simple to use, drill a 3/4 to 7/8" dia hole in the center of the hole you want to open up, install the dies upper half on top, thread the lower die on the shaft untill it hits the underside of the hood and all the slack is taken up from the die, then just pump the handle of the jack, and presto, nice clean hole, no burrs, no chipped paint, no metal distortion, nothing, just a clean hole...practice the set up on a piece of scrap metal until you learn how to assemble the die, and any spacers required, because you want to do it once, and do it right
FYI, you want an Industrial Grennlee set up, as they range up to 6" hole dia.'s
Re: Sheet metal cutting [Re: DAYCLONA] #1565011
01/18/14 04:16 PM
01/18/14 04:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a small Greenlee...
Re: Sheet metal cutting [Re: DAYCLONA] #1565012
01/18/14 04:26 PM
01/18/14 04:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I use a Greenlee punch to knock the holes out in the top's of Charger fenders for under the fender scoops...no distortion, no mess, it takes longer to drill the 7/8" dia hole required for the arbor than it does to punch a hole...every car builder should have a set
mike
Re: Sheet metal cutting [Re: DAYCLONA] #1565013
01/18/14 04:27 PM
01/18/14 04:27 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Thats pretty slick..
Re: Sheet metal cutting [Re: GKMOPAR] #1565014
01/18/14 04:40 PM
01/18/14 04:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Gerry, if you decide to use a Greenlee punch set, I'd use a Uni-bit to drill the required hole for the arbor...and you could also generate a hole using a small "hand" Greenlee, that requires a 3/8" dia starting hole, then you use the "hand" Greenlee to open up a hole for the arbor shaft on the hyd unit
FYI...Greenlee's are also available to make square and rectangular and oval holes in sheetmetal
Re: Sheet metal cutting [Re: DAYCLONA] #1565015
01/18/14 05:52 PM
01/18/14 05:52 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
you could try it with offset aviation snips. I have cut 8' lengths of 18 GA steel with them and you can also cut fairly tight curves . you would just need to cut a hole to get them started .
midwest aviation offset snips
Re: Sheet metal cutting [Re: dirt] #1565016
01/18/14 06:31 PM
01/18/14 06:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hole saw ... run it backwards. Takes longer but it will do a nice job.
Re: Sheet metal cutting [Re: dirt] #1565017
01/19/14 01:45 AM
01/19/14 01:45 AM
cbusters Offline
cbusters  Offline
Snips will stretch the metal and a hole saw will heat and warp the metal. Use the knockout punches.
Re: Sheet metal cutting [Re: DAYCLONA] #1565018
01/19/14 02:45 AM
01/19/14 02:45 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Start small. Drill a small hole for a 7/8" punch, then move up to the big punch with the larger arbor.
Re: Sheet metal cutting [Re: GKMOPAR] #1565019
01/19/14 08:52 PM
01/19/14 08:52 PM
Jacksonville Florida
elitecustombody Offline
Drill, air body saw,die grinder with carbide bit for clean up or Greenlee kit
Re: Sheet metal cutting [Re: GKMOPAR] #1565020
01/20/14 12:24 AM
01/20/14 12:24 AM
MN
astrobuf Offline
astrobuf  Offline
MN
I've actually had very good luck trepanning sheet steel using a Malco circle cutter.
http://www.amazon.com/Malco-2-Inch-12-Inch-Cutter-Accessory/dp/B000289542
The Greenlee punches would be great, but very expensive.
I've used my Malco to cut up to 8 inch diameter circles using a hand drill. It worked surprisingly well.
Astrobuf
So, are you really a Rocket Scientist?
Re: Sheet metal cutting [Re: astrobuf] #1565021
01/20/14 01:07 AM
01/20/14 01:07 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I do like the greenlee but it is a bit expensive for the limited times I may use it. The Malco cutter looks like a more affordable alternative.
Re: Sheet metal cutting [Re: GKMOPAR] #1565022
01/20/14 01:30 AM
01/20/14 01:30 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Just practice a time or two before you do the real surgery. Go slow, have someone help you, say by spray oiling the cutter as you work your way around. Test the cut radius as I've noted the scale on the tool is off by a a bit (1/32 or so on 8 inches diameter in my case)
Astrobuf
Re: Sheet metal cutting [Re: GKMOPAR] #1565023
01/20/14 02:00 AM
01/20/14 02:00 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dude,...google is your friend, Sunbelt Equipment and Tool Rental in Hilliard Ohio, your home town, rents Greenlee equipment 5274 Cemetery Road Hilliard Ohio call them at 614 876 2605
Mike
Re: Sheet metal cutting [Re: DAYCLONA] #1565024
01/20/14 05:10 PM
01/20/14 05:10 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I checked it out online with Sunbelt Saturday and did not see it listed. I called them today and they did not have one local but could get it. It would cost about $100 for them to ship it from another location and rent to me.
Re: Sheet metal cutting [Re: GKMOPAR] #1565025
01/20/14 07:49 PM
01/20/14 07:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Gerry, sounds good! if you go this route, you'll need the 3 1/2" Greenlee punch as the actual hole size punched is 1/2" larger, I measured my set, the 3 1/2" punch will give you a hole dia of 4.020", just a whisker (5 human hairs actually) over 4" the Greenlee pn# for the 3 1/2" die pcs are:2982AV for the punch, and pn# 2981 for the die, make sure the set you rent has those, as Greenlee makes multiple set cases up to 6"
Mike
