Yeah, Brian I'm with you!
The cam I put in that 416 stroker with the manifolds was very similar to that 440, a single pattern ~237 @ .050 on 112 in at 107, It's a torque BEAST that idles sweet and still pulled the heavy car up high. I think something similar would work on domingo's car and still have plenty of idle vacuum and part throttle cruise torque. My gut would be to put a 244/246-ish @ .050 solid in it and be a bit better down low AND up high.
Wish my old 440 had a set of ported stealth heads and slicks, trying to launch a B/E body on street tires (not even drag radials) was about like launching on ICE.
My buddy's Chrger has a 440-6 with a 251/257 @.050 Comp cam and runs high 11's with only 3.23
![](/ubbthreads/images/graemlins/eeek.gif)
gears. He's running 2" headers, close to 11:1 and a good 9" converter though, which helps him launch. He drives it everywhere as well. Wouldn't run that cam with manifolds though
![](/ubbthreads/images/graemlins/tsk.gif)
But he doesn't even run drag radials, he runs that 4 shock (2 mounted horizonally about the rear leaf segment) traction system and it obviously works good.
You can still build some awesome 440 combos that are still impressive these days!
