Re: Installing an OEM Thermostat Housing. [Re: RapidRobert] #1561465
01/12/14 12:29 PM
01/12/14 12:29 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Interesting to see how long a thread can get over sealing a thermostat housing and even more interesting on all the ways people go about the repair.
ie; don't do it if it's this temperature, only use this or that housing, this sealer, that sealer, etc., etc.....
The solution is really straight forward and simple
Clean flat surfaces, inspect for imperfections on sealing surfaces, thread sealant on bolts that are exposed to fluids, proper torque and a quality gasket. DONE
Re: Installing an OEM Thermostat Housing. [Re: therocks] #1561466
01/12/14 04:22 PM
01/12/14 04:22 PM
Pyper if the permatex is the non hardening type thats what I use.I never remember the number.Rocky
Oh it gets better. Rock as a person that uses alot of Permatex #1 and #2 an easy way to remember the difference between the two is this analogy; for instance if 2 guys were vying for a gals' affections & if 1 guy could get hard (& stay hard) and 1 guy stayed soft, well the guy that got hard would be #1 (in her eyes) and the guy that stayed soft would be #2 (if that). I hope that helps you. RR
