How to tell if car is coupe or 2 door sedan model #156056
11/24/08 06:51 PM
11/24/08 06:51 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
1969 GTX. How do you determin if car is a coupe or a 2 door sedan model?
Re: How to tell if car is coupe or 2 door sedan model [Re: frank] #156057
11/24/08 06:55 PM
11/24/08 06:55 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Any 69 GTX with a roof will be a hardrop, the rear windows will roll down and no post
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: How to tell if car is coupe or 2 door sedan model [Re: frank] #156058
11/24/08 07:00 PM
11/24/08 07:00 PM
3RD AND 4th digits of the vin
21 is a 2 dr sedan
23 is a 2 dr hardtop
27 is a convertible
29 is a 2dr sports hardtop(baracuda)
I hope this helps
Re: How to tell if car is coupe or 2 door sedan model #156059
11/24/08 07:07 PM
11/24/08 07:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
A coupe and a sedan are generally considered to be the same thing.
I think you may be thinking of a 2 door hard top as compared to a 2 door sedan? If so, as mentioned above, the VIN will tell you which one is which.
RL21 = R:Plymouth L: Low Line 21:2 door Sedan
RS23 = R:Plymouth S: Special 23:2 door Hard Top
Re: How to tell if car is coupe or 2 door sedan model #156060
11/24/08 07:13 PM
11/24/08 07:13 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks. I'm trying to order parts from year one and they list coup and sedan. Do you know if year one considers a hardtop a coupe?
Re: How to tell if car is coupe or 2 door sedan model [Re: frank] #156061
11/24/08 07:16 PM
11/24/08 07:16 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just tell them if your car has a pillar post between the front and rear side glass or not. All Sedans had them.
Re: How to tell if car is coupe or 2 door sedan model [Re: ScottSmith_Harms] #156062
11/24/08 07:28 PM
11/24/08 07:28 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
APPRECIATE ALL THE GOOD INFO. THANKS
Re: How to tell if car is coupe or 2 door sedan model [Re: frank] #156063
11/24/08 07:43 PM
11/24/08 07:43 PM
Maine
itali83 Offline
itali83  Offline
Maine
Can't get any easier than this. Sedan = pop out rear windows Hardtop/coupe = roll down rear windows
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: How to tell if car is coupe or 2 door sedan model [Re: itali83] #156064
11/24/08 08:24 PM
11/24/08 08:24 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
The rear windows in my 75 Coronet hardtop, WH23 didn't roll down.
Re: How to tell if car is coupe or 2 door sedan model [Re: formula_s] #156065
11/24/08 08:39 PM
11/24/08 08:39 PM
I''m still confused Are coupes/sedan the same(both have a post)
Re: How to tell if car is coupe or 2 door sedan model [Re: RapidRobert] #156066
11/24/08 08:57 PM
11/24/08 08:57 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
It depends on the manufaturer, but I have always thought a sedan and a post car were the same thing, and a hardtop and a coupe were the same!
JB Rhinehart, Realist
A-Body's RULE!
Re: How to tell if car is coupe or 2 door sedan model [Re: frank] #156067
11/24/08 09:28 PM
11/24/08 09:28 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
http://www.carnut.com/photo/list/ply/ply48.html
The way it was. Later on, when the so-called hardtop convertible was marketed, the two-door would be called a "sport coupe". "Sedans" would have pillars between the doors, or doors and rear windows. There were four door hardtops too. I had a '69 Ford LTD 4 dr hardtop. Roll all of the windows down, and it was wide open on each side. http://www.ssb7.net/users//26142/69fordltd4door.jpg
My $0.02
Re: How to tell if car is coupe or 2 door sedan model [Re: itali83] #156068
11/24/08 09:30 PM
11/24/08 09:30 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
"Post coupe" is usually what I hear, and have said myself coupe for cars with a post for years. Windows pop out. RM21
Hardtop has no pillar, roll down windows. RM23
Have seen/heard it called pillarless hardtop.
Re: How to tell if car is coupe or 2 door sedan model [Re: SomeCarGuy] #156069
11/24/08 09:52 PM
11/24/08 09:52 PM
Maine
itali83 Offline
itali83  Offline
Maine
I said this in response to him having a '69 B-body. I wasn't clear about that. I know 68-69 B-bodys hardtop= roll down rear windows and sedan= post with popout windows.
Re: How to tell if car is coupe or 2 door sedan model [Re: itali83] #156070
11/24/08 11:48 PM
11/24/08 11:48 PM
SomeCarGuy Offline
SomeCarGuy  Offline
That is what I'm talking about also, a '69.
Re: How to tell if car is coupe or 2 door sedan model [Re: Rhinodart] #156071
11/25/08 09:08 AM
11/25/08 09:08 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: How to tell if car is coupe or 2 door sedan model [Re: frank] #156072
11/25/08 10:46 AM
11/25/08 10:46 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Growing up as a kid (I'm old) a 2 door with no post was a hardtop, 2 door with a post a coupe, 4 door with a post a sedan. 4 doors without a post was cool. Most everyone I know goes by this too.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: How to tell if car is coupe or 2 door sedan model [Re: Junky] #156073
11/25/08 10:59 AM
11/25/08 10:59 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Post = sedan
roll all the windows sown and you can sweep your arm from the windshield to the rear roof post = hardtop.
The problem is that the automakers built different cars over the years, so the rules got blurred.
In your specific case (1969 B body), the VIN will tell you what you have and will be easier to pass along to year one for ordering.
Re: How to tell if car is coupe or 2 door sedan model [Re: Junky] #156074
11/25/08 11:05 AM
11/25/08 11:05 AM
Kirkland, Washington
Pacnorthcuda Offline
I agree with this. Also the 4 door without a post can obviously be called a hardtop, or a "4 door hardtop" An example would be a Buick Electra 225.
Only problem is that there is no "2 door sedan" in the above definition, which many people would say in a post car, if the rear 1/4 windows roll down its a sedan, if they don't (or they just pop out) like a Volare/Aspen its a coupe, but thats kind of a fine distinction.
Re: How to tell if car is coupe or 2 door sedan model [Re: moparmarks] #156075
11/25/08 11:33 AM
11/25/08 11:33 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not correct.... A hardtop has no B-Pillar. A Coupe has a B-Pillar (post).
The line between a 2-dr sedan (post) and a coupe gets blurry, I tend to differetiate between posts & coupes as: A coupe has almost no rear window (E body cudas & Challengers are coupes), while a post has a roll down or pop out, larger rear window (roadrunner)
One things for sure, there is no hard fast rule with coupes vs. posts vs. 2-dr Sedans. These are all basically the same.
