Needed, Expert welder help #1560071
01/06/14 07:50 PM
01/06/14 07:50 PM
fredericksburg,va
cudaman1969 Online sleepy OP
cudaman1969  Online Sleepy OP
fredericksburg,va
I have run in to a problem welding some cast iron pieces, and need some advice. I using a stick welding rod without the coating and using my tig welder. The problem I'm running into is the weld bead is porous and won't flow( little holes and craters) and is almost black, Is it too hot, wrong gas, dirty? The rod is for welding cast iron and machinable. It's been said it can be welded this way, but I'm doing something wrong. HelpI
Re: Needed, Expert welder help [Re: cudaman1969] #1560072
01/06/14 08:14 PM
01/06/14 08:14 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Are you preheating?
Call your local Lincoln Sales office, they will give you some pointers.
Joe
Re: Needed, Expert welder help [Re: jlatessa] #1560073
01/06/14 10:12 PM
01/06/14 10:12 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think the problem is that the rod is made for stick welding. Surprisingly, arc rods are very peculiar - not just a piece of wire coated with flux !!
You'd do well to post your question on a welding site. Weldingtipsandtricks.com would be a good place to start or in the Miller forums.
Re: Needed, Expert welder help [Re: Stanton] #1560074
01/06/14 10:19 PM
01/06/14 10:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Needed, Expert welder help [Re: pittsburghracer] #1560075
01/06/14 11:39 PM
01/06/14 11:39 PM
MN
astrobuf Offline
astrobuf  Offline
MN
This is hard enough to do when you know what you are doing. I'd give the job to an experienced cast iron welder, else you will just be chasing problems.
If you could braze it, you might be able to do it yourself.
http://www.toolsandgarages.com/index.php?topic=839.0
Astrobuf
Re: Needed, Expert welder help [Re: cudaman1969] #1560076
01/07/14 01:11 AM
01/07/14 01:11 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Who gave you this idea? Doubtful that would work under any circumstance but I suppose worth a try. I would have left the flux on it.
I've used the arc rods in an arc welder before and you have to really crank the heat, use a darker shade in your helmet and let 'er rip. There's lots of fire, sparks and noise: cheap entertainment. It's similar to a 6010 in behavior.
Otherwise, you can gas weld it with a cast iron rod and a large tip. I found moving the torch quickly and keeping the rod almost melting hot worked pretty good.
Mo' Farts
Moderated by "tbagger".
Re: Needed, Expert welder help [Re: Grizzly] #1560077
01/07/14 02:39 AM
01/07/14 02:39 AM
fredericksburg,va
fredericksburg,va
thanks for the answers, i'll try that web site
Re: Needed, Expert welder help [Re: cudaman1969] #1560078
01/07/14 10:35 PM
01/07/14 10:35 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I use a nickle cadium rod to weld cast with & you have to preheat
You can mig it if you preheat it
Re: Needed, Expert welder help [Re: BulletBob] #1560079
01/08/14 03:17 AM
01/08/14 03:17 AM
fredericksburg,va
fredericksburg,va
Yes, i went to the website from the above post and they had a nice video on preheating high carbon alloys. We all have to start at the beginning, even the expert,they weren't born with the knowledge. Can't be afraid of trying.
