Re: Torque converters
[Re: tsanchez]
#1559833
01/06/14 03:28 PM
01/06/14 03:28 PM
Posts: 250 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
i would call Lenny at Ultimate Convertor. I got one from Lenny last year.
I gained 2 mph, 3 tenths, and my 60' jumped to 1.55 from 1.70.
I changed nothing else but convertor.
[Re: tsanchez]
#1559837
01/06/14 03:42 PM
01/06/14 03:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Not so worried about the 60 foot but that it wont rpm right, always seems like its loaded, never two strokes or gets on the cam. Also mph is low, the 1/8 mile times and mph are better than at 1/4. This engine should be pushing it to 133 or so.
starving for fuel maybe. your jet change didn't do anything. maybe its not the converter
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Eric]
#1559840
01/06/14 04:14 PM
01/06/14 04:14 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Cut and pasted from Moparts fastest section. Seems like you are right where you should be mph wise. I'm down some running 10.06@130mph but 4.88 gears, a small carb, and a 550 lift cam will kinda peter out. 10.27 @ 129.9b 68 fb cuda 2980 lbs, 9.0x30 tire,leaf springs. 500”, 4150 carb, indy ez-1s Footin it cudasteve68 10.31 @ 131.85, 1.36 60', Kevins440, 493RB, Indy 440-1's, stock '63 cross ram, 3300lb. 10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.38 @ 128 mph, 1.44 60', 68 Valiant 100, 408, Indy 360-2s, pump gas, 3100 lbs, 340_Dart 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 10.43 @ 126.41 1.42 60’,70 Superbee 451,3500 lbs,SS sprgs,Std port EZ's, super451b 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.500 @ 131.05,03 Dakota R/T Turbocharged 408, rtspeedemon 10.50 @ 128.00,1979 Chrysler 300,Bown 408 SB,727,4:56 gears Crizila 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, 400 stk bot end E heads,w squeeze, pump gas,BB70DUSTER 10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.57 @ 126, 1.45 60’3650#, 66 Coronet440,9in slks.cal tracs,no pwr aders, theman440. 10.58 @ 125,1.44 60’,70 dart,493,pump gas,eddy rpm's,solid cam,493 Dart 10.59 @ 127, 1.49 60' 70 Bee 440 eddy rpm heads 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.6167 @ 133.65, 4190#.030 over 360, Sgl Turbo, 99 Dakota, Duner 10.62 @ 125mph,69 Cuda, 394"SB IMM ported Eddies,IMM flat tappet, Pump gas, 275 Radials, imin269 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.67 @ 128.3, 1.55, 72 Chally, Auto/Pump Gas Street Car, 3850, full exh, DOT's *WeDgiE* 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.68 @ 125, 73 Str/Strip Dart stock 440/727 pump gas ET Streets Mopar65 10.68 @ 123 mph. 76' Volare 406" iron head magnum motor, 904 trans, 3300 lbs on 9" Radials. Hyd roller camshaft -- StandOnIt 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.71 @ 126.12, gj69charger, '69 charger, 500cid
[Re: tsanchez]
#1559841
01/06/14 04:36 PM
01/06/14 04:36 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
If you think it should MPH at 133 then you should also think you should ET at 10.0 or better.
Russ
[Re: max_maniac]
#1559842
01/06/14 04:47 PM
01/06/14 04:47 PM
Posts: 235 Gilbert AZ
tsanchez
Gilbert AZ
Russ
Exactly, I can find the et once the mph is there, engine should be capable, its 12.4-1 heads flow in the 360 range and cubic inches at 436, tunnel ram with two dominators, cam is .794/.746 278/286 at .050 on a 110 center. even if the combo is wrong and doesnt 60 or et right when it comes on it should mph out the back and its just not. Old iron headed 401 with a flat tappet was running 11.2 at 122 with same converter, had been in car for 25 yrs and then et dropped to 11.7 and 118 so I thought engine was tired so it came out and new one built. it still has same issue so I think that is where its at as drastic tuning changes really make not much difference.
[Re: Thumperdart]
#1559847
01/06/14 06:52 PM
01/06/14 06:52 PM
tsanchez
Gilbert AZ
Turns right at 6900-7000 at the stripe.
Did you get my pm? With that cam and head combo you should be solidly in the 9`s unless it`s a heavy pig AND that`s w/a Continental vert.........
Guess this is an example how "easy" n/a tuning is.........
Yes I got your pm, thanks! and yes it kinda is a heavy pig (3500) but it should still pull on the big end. Hell last yr I took out 200 lbs and didnt really make a difference.
[Re: tsanchez]
#1559850
01/06/14 07:54 PM
01/06/14 07:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It ran 10.53 at 126 in bowling green this fall at drag week. 1.51 60, car weighs 3500lbs, 4.44 gear and 28 inch tires.
Being it was HOT down there thats what the HP shows for that day... the ET and MPH is right in line so thats what it had for power that day.... what was the A/F ratio that day
[Re: MR_P_BODY]
#1559851
01/06/14 08:27 PM
01/06/14 08:27 PM
tsanchez
Gilbert AZ
Dont know, the wideband took a crapper when the battery and msd exploded never have had a chance to check full throttle readings. They are pretty close as far as plug readings go.
6.69 at 103.49 1/8th on that pass
[Re: tsanchez]
#1559852
01/06/14 10:53 PM
01/06/14 10:53 PM
Posts: 9,791 MI, usa
dvw
MI, usa
First for a race converter, I've been very happy with Lenny from Ultimate. Second, I ran the N/SS 10.50 index for years. The numbers when the car was set to go 10.50, 1.45-1.47, 6.70@103/104, 10.50@127. I'd say your numbers line up. with a 4.44 and 28" 6900rpm is pretty decent for slip. I think it's down on HP. Doug
[Re: 1967dartgt]
#1559854
01/06/14 11:33 PM
01/06/14 11:33 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
On a serious note call Lenny and give him your specs he will fix you up. I have had a few convertor problems tci and dynamic so I know what you are saying.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: tsanchez]
#1559858
01/08/14 01:28 AM
01/08/14 01:28 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Your 1/4 mile Et and MPH are right on.
Your 60 ft.s are off, so I would work on that first. Your 1.51 60 ft. is a 11.20 ET indicater. So your MPH isnt low at All for your ET.
It may be low for your engines expectations, but its not low for its ET. Your 60FT. times however are low for your MPH and ET.
Get your 60 ft. times to match first, then worry about what you think this engine should be pushing ET wise. One thing at a time.
EDIT. If you think it should MPH @ 133, then It should 60 ft. @ around 1.39 or below.
[Re: Thumperdart]
#1559861
01/08/14 02:52 PM
01/08/14 02:52 PM
tsanchez
Gilbert AZ
This is a street car that weighs 3500 lbs with no trans brake so I would say its ok. It is dead consistent but the et its running can be done with much less engine so I want to find out what the problem is, if its engine then Ill adress it but this is already the second one, first started acting the same so I assumed it was tiring out.
I see this a lot and the first thing I do is give the motor a cranking comp. test or leak down your choice, then go from there. If you have a hurt or wounded piece then nothing will help. Then ign. test etc. Then of course converter. Did you flash test you vert?
Leakdown is good, compression is where it should be for camshaft timing etc, all looks good, ign phasing and timing checked, different boxes and tachs, checked fuel system and changed, all with no effect. Flash test was to 5500 in 3rd. My process of elimination has led me to the converter or maybe a trans issue, sprag etc, dunno. I appreciate the opinions, keep them coming.
[Re: pittsburghracer]
#1559864
01/08/14 03:50 PM
01/08/14 03:50 PM
tsanchez
Gilbert AZ
I kinda get a kick out of this statement. Your 60 foot time is the most important part of the run whether you are a bracket racer or going for a "new best". It all starts right there and the rest of the run is the easy part.
I realize that but Im more concerned with where the mph is right now, The 60 ft and et will come later. Obviously I should have engine dynoed it to know where it should be but I have a friend with the same basic build, has 11-1 compression, smaller roller cam and a sinlge carb and car is within 200 lbs of mine, he is trapping 135, he has chassis issues keeping his et at 10.20 or so but it is showing good hp. That is what im looking for is lost hp, not et right now.
Car has ladders and single adj qa1 coils.
[Re: Thumperdart]
#1559866
01/08/14 04:15 PM
01/08/14 04:15 PM
tsanchez
Gilbert AZ
Maybe the t-ram is the problem because I always hear about single carbs and intakes out performing t-rams these dayzz.......... Comparing different combos isn`t always accurate anyhow........
These intakes are amc only and usually show 40-60hp over singles most of the time, the indy amc intake is really not that good and is what he has. I have thought of putting the single on to try it but, I like the duals lol been on there for 30 yrs. The reason I think its conv is the last engine was down 5+ mph also, I just assume it was the tired engine.
[Re: Thumperdart]
#1559872
01/08/14 08:50 PM
01/08/14 08:50 PM
1967dartgt
Hilltown Pa
What west coast cars does he do? I like to try new things but Lenny has done good by me. I know of a few heads up cars around here with ptc and digby dental uses them in his dart. He went 4.9s with caltracs and there conv, so it's made me think about them.
[Re: 1967dartgt]
#1559874
01/08/14 09:27 PM
01/08/14 09:27 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
They were some of the finest converters I used when I was running door cars in the 3200lb range. That said, I would suggest putting a single carb manifold with one dominator on it. Hopefully you know someone that has one. That sounds like a ton of CFM for a small engine. JMO It's not to say that you can't run two, but it would need to be in the 8500RPM range with a very loose converter, like 7000 stall. You should be running a very loose 8" converter.
[Re: camastomcat]
#1559876
01/08/14 11:11 PM
01/08/14 11:11 PM
tsanchez
Gilbert AZ
I do have an intake and carb, just every time I tried in the past it was 2 tenths and 3mph slower, my dominators are the 750cfm ones that are basically a 2 circuit 1050 with flared boosters. At this time I think they have too much signal as I have to really lean em out to run good afr. thought about even changing them to straight boosters and make em 1050s as most of the guys I know are using 1050 and 1150s with great results.
[Re: tsanchez]
#1559878
01/09/14 01:48 AM
01/09/14 01:48 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Looking at maybe changing converters, current one was built by a friend 25yrs ago. Its a 8 inch and he refreshed it this spring but I feel its holding car back, it should be mph in the 130s and so far has only gone 126. Feels like its on a dyno all the time, never pulls rpm strong.
Who makes a good 727 converter in the 55-6500 stall range. This is for my AMC but there is really no difference in converter but the ring for starter.
Nothing else but the highlighted should matter here. TRY a converter. Some things may have changed in 25 years.
Monte
[Re: Monte_Smith]
#1559879
01/09/14 01:52 AM
01/09/14 01:52 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I agree and he and I had a good phone chat today and that seems to be the main area that needs some fixin...........
