I replaced the K member in my Charger in May. I found that the RH motor mount was broken at that time so I scrounged around my stash and found a decent used one. The rubber portion looked thicker than the old broken one but I figured that the old one was just compressed and worn.
The thicker RH mount raised that side but also moved the LH header closer to the steering box. Because of that, the header would now sometimes make contact. Looking at the LH mount, it appears that it is thinner than the right by a noticeable amount.
I estimate the thickness of the LH (drivers side) mount to be 3/4" to 7/8" and the RH side to be 1" to 1 1/8". I would simply switch them side to side but the LH is one of the interlocking types to avoid failure. Looking at the Schumacher (spelling?) site, the pictures they show make their mounts look at least 1 1/4" thick. Today I checked at a local parts store and found that their replacement mounts are at least 1 1/8".
Have you found a variance in thickness of your motor mounts? I found that the 66-72 B, 70-74 E and many C body cars use this same mount.
http://www.engine-swaps.com/Pages/ProductsYear/66.72bBody.html#head2I thought maybe I could move my LH mount to the right and install a new Poly-Lock one in the left side. The goal here is to get more clearance for the header. Before the K member swap and RH mount replacement, there was plenty of room there.
