440/6, Sanden a/c compressor, how I did it....
#1559375
01/05/14 07:53 PM
01/05/14 07:53 PM
Posts: 1,567 Ky
jt4406
Ky
For anyone planning a six pack on their 440 and has or wants a/c, a few pics of how I did it. Jess
Yeah, it's hopped up to over 160...
Re: 440/6, Sanden a/c compressor, how I did it....
[Re: jt4406]
#1559376
01/05/14 07:55 PM
01/05/14 07:55 PM
Posts: 1,567 Ky
jt4406
Ky
view from driver fender....
[Re: jt4406]
#1559377
01/05/14 07:57 PM
01/05/14 07:57 PM
Posts: 1,567 Ky
jt4406
Ky
driver side flex line, and hard line...
[Re: jt4406]
#1559378
01/05/14 08:02 PM
01/05/14 08:02 PM
Posts: 1,567 Ky
jt4406
Ky
pass side hard line ( I just ordered aluminum line of the correct size, with the ends I needed and bent it to fit, readily available from the aftermarket a/c suppliers)
[Re: jt4406]
#1559379
01/05/14 08:04 PM
01/05/14 08:04 PM
Posts: 1,567 Ky
jt4406
Ky
I put bulkhead connectors at the firewall to attach the hoses to....
[Re: jt4406]
#1559380
01/05/14 08:07 PM
01/05/14 08:07 PM
Posts: 1,567 Ky
jt4406
Ky
Picked up used receiver/drier bracket at the nats this year....
[Re: jt4406]
#1559381
01/05/14 08:09 PM
01/05/14 08:09 PM
Posts: 1,567 Ky
jt4406
Ky
used an aftermarket condenser, biggest I could fit into it.....
[Re: jt4406]
#1559382
01/05/14 08:11 PM
01/05/14 08:11 PM
Posts: 1,567 Ky
jt4406
Ky
180 degree fitting coming off compressor high side....
[Re: screamindriver]
#1559384
01/05/14 09:02 PM
01/05/14 09:02 PM
Posts: 1,567 Ky
jt4406
Ky
Didn't use a kit, I jumped the gun 10 years ago and bought a sanden compresser and a universal evaporator/heater/defroster box from Vintage Air, designed, I believe, for street rod use. This was before anyone was offering a kit for an e body. I made the compresser brackets from factory bb a/c brackets and made up everything else from universal fit stuff. Nope, single groove w/p pulley. jess
[Re: jt4406]
#1559385
01/05/14 09:23 PM
01/05/14 09:23 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
you did a great job on your A/C install......most people don't understand how much work is takes to get the A/C working in our old cars and especially look as good as your car's install looks.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: shanker]
#1559386
01/05/14 09:32 PM
01/05/14 09:32 PM
Posts: 1,567 Ky
jt4406
Ky
Thanks, you are right, lots of fitting, removing, tweaking, reinstalling, etc.....here's a pic of what the lines at the firewall connect to inside car..... jess
[Re: jt4406]
#1559387
01/06/14 12:09 AM
01/06/14 12:09 AM
Posts: 7,197 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
You did a nice job...I'm wondering. ..Do you think it might need some insulation{or wrap} on the hard lines inside the cabin ??...Something as simple as the foam waterline insulation from lowes...Just to keep the condensation/temp transfer down to a minimum...The only reason I ask is because most factory and aftermarket kits have some sort of drip tray designed into the system to catch the condensation coming off the steel parts inside the cabin... I had trouble smoking the single WP belt when the 6 bbl kicked in ..I"m using the dayco top cog belts and they just would'nt hold no matter how tight it was adjusted...You kicked it and it was squealing.....But I've got a touch over 500hp and it winds up fast for a belt configuration that was never meant to have that kind of torture... The double groove pulley cured that...
#1559388
01/07/14 10:48 AM
01/07/14 10:48 AM
Posts: 1,567 Ky
jt4406
Ky
You're right Colin, I still have to wrap the larger a/c line from the box to the firewall. The evaporator kit had the wrap included with it. There is a drain hose routed out of the bottom of the evaporator box that has to go outside the car, (drats, another hole to drill). If you noticed there are no clamps on the heater hoses yet either. I also am installing the heater control valve in one of the flexible hoses under there before I finish up. As far as the one belt water pump pulley, I haven't driven the car with this configuration of belts, so I don't know if it will squeal under high rpm or not... jess
[Re: jt4406]
#1559389
01/07/14 01:30 PM
01/07/14 01:30 PM
Posts: 4,799 ILL
MLR426
ILL
Nice install, but you should have cut the extra mounting lugs off the compressor and had a condenser made for both inlet and outlet connections to connect at passenger top corner of the condenser to eliminate the driver side hose,for a cleaner look of both. Just my opinion.
MLR426
[Re: MLR426]
#1559390
01/07/14 02:37 PM
01/07/14 02:37 PM
Posts: 1,567 Ky
jt4406
Ky
I actually thought about that, but the three hoses (low side a/c, and both heater) coming by the dist is tight now, and I felt that the extra hose would make that situation worse. Also, the high side hose on factory a/c cars follows that route, so I was ok with it. jt
[Re: jt4406]
#1559393
01/07/14 07:41 PM
01/07/14 07:41 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
I don't have any recent pics, but here's how mine looked a few years ago.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1559394
01/07/14 07:42 PM
01/07/14 07:42 PM
jbc426
West Coast, USA
