Brake Push Rod Help #15589
06/20/05 06:07 PM
06/20/05 06:07 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
This is a push rod of a 70 Dart with 10in drum brakes. How do you get it a part ??? I need to get the pistons off the rod I unscrewed the end and the spring came off but I need only the push rod? Thanks
See att.
Re: Brake Push Rod Help [Re: DAMOPARS] #15590
06/20/05 06:11 PM
06/20/05 06:11 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Pull hard, sometimes pull very hard, sometimes pull VERY hard.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Brake Push Rod Help [Re: DAMOPARS] #15591
06/20/05 06:12 PM
06/20/05 06:12 PM
pull really hard.
clamp the pushrod in a vice close to the piston, but leave enough room to put two open end wrenches between the piston and vice, and then pry the piston off the rod with the wrenches.
Re: Brake Push Rod Help [Re: amxautox] #15592
06/20/05 06:14 PM
06/20/05 06:14 PM
amxautox Offline
amxautox  Offline
put a round rod thru the brake rod's end
'hook' the round rod on the side of a vice with the brake rod's end in the vice
put an open wrench over the small dia of the rod and up against the piston and hit the wrench with a hammer to pop the brake rod out of the plastic bushing inside the piston end.
Tom
author unknown
Re: Brake Push Rod Help [Re: amxautox] #15593
06/20/05 06:19 PM
06/20/05 06:19 PM
VA
DAMOPARS Offline OP
DAMOPARS  Offline OP
VA
Thanks Tom and Greg
Back at it
Re: Brake Push Rod Help #15594
06/20/05 06:24 PM
06/20/05 06:24 PM
amxautox Offline
amxautox  Offline
Good picture, I hadn't seen that one before. Thanks Greg.
Tom
author unknown
