64 Fury Throttle opening question #155905
11/24/08 02:24 PM
11/24/08 02:24 PM
The Scratch, WA
P
Part_Stalker Offline OP
P
The Scratch, WA
I am working on my winter project and ran into my first issue. When depressing the gas pedal I only get about half travel. Mopar shop that worked on it said it was the kickdown linkage which was the later 3 piece style and not the one piece rod. I was more thinking that it could be the throttle cable as the car was originally a poly 318 and now is a 383. Any suggestions? It didn't occur to me to check the 64 Fury against my 65 Coronet until I had put them away. Questions would be 1) What is the interchange for the kickdown linkage and throttle cable(early B body big block 4v or would 2v items work) as I have a 64 Fury 361 sitting next to the shop also. Thanks for the help.
Re: 64 Fury Throttle opening question [Re: Part_Stalker] #155906
11/24/08 02:33 PM
11/24/08 02:33 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
With my '65 "B" body, I have the stock 273 2bbl cable on my big block sixpack setup. No problem. Just need to adjust the cable. Manual valve body though. No kickdown linkage.
This is the land of the free because of the brave
Re: 64 Fury Throttle opening question [Re: Part_Stalker] #155907
11/24/08 05:03 PM
11/24/08 05:03 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
318 cable should work,i'm using one on a 64 polara with a 383 no prob. also using three piece kick down linkage. just stock rr intake no spacer.
Re: 64 Fury Throttle opening question [Re: pushbutton] #155908
11/25/08 02:18 PM
11/25/08 02:18 PM
The Scratch, WA
P
P
The Scratch, WA
Thanks guys. It sounds like maybe a little adjustment is in order. Pushbutton how did you route your heater hoses around that 3 piece linkage?
Re: 64 Fury Throttle opening question [Re: Part_Stalker] #155909
11/25/08 07:14 PM
11/25/08 07:14 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I had to run one on the left and one on the right of the carb.
