Re: Brake Push Rod Help
[Re: DAMOPARS]
#15590
06/20/05 06:11 PM
06/20/05 06:11 PM
Posts: 96,660 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Pull hard, sometimes pull very hard, sometimes pull VERY hard.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: DAMOPARS]
#15591
06/20/05 06:12 PM
06/20/05 06:12 PM
pull really hard. clamp the pushrod in a vice close to the piston, but leave enough room to put two open end wrenches between the piston and vice, and then pry the piston off the rod with the wrenches.
[Re: amxautox]
#15592
06/20/05 06:14 PM
06/20/05 06:14 PM
amxautox
put a round rod thru the brake rod's end
'hook' the round rod on the side of a vice with the brake rod's end in the vice
put an open wrench over the small dia of the rod and up against the piston and hit the wrench with a hammer to pop the brake rod out of the plastic bushing inside the piston end.
Tom
author unknown
