TA block engine mount ?? #1558378
01/03/14 10:00 PM
01/03/14 10:00 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
I was looking at my engine mount and noticed that this didn't look right.
Is there a bolt / spacer part number that I need?
Not a very good picture, sorry.
It is the left hand side rear bolt, that doesn't come thru the nut.
AAR cuda 71 rag challenger
Re: TA block engine mount ?? [Re: 3406pac] #1558379
01/04/14 01:22 AM
01/04/14 01:22 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
No spacer required, looks like you may have a 318 bracket instead of a 340 mount. You will have to zoom in but you can see it in this picture.
Careful, your character's showing!
Re: TA block engine mount ?? [Re: mopar346] #1558380
01/04/14 03:52 AM
01/04/14 03:52 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Any way to confirm that?
Besides pulling the mount off.
Are the 318 mounts wider?
Re: TA block engine mount ?? [Re: 3406pac] #1558381
01/04/14 04:02 AM
01/04/14 04:02 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Todd I have a pair of the correct mounts if you want to come by and pick them up to compare them with yours.
Re: TA block engine mount ?? [Re: 3406pac] #1558382
01/04/14 04:06 AM
01/04/14 04:06 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
340 mounts are wider, had to use a spacer between the motor and mount on mine with 318 mounts. 340 mounts were mia at the time.
-Daty
