What's the best small block heads/motor for boost?
#1556387
12/30/13 10:46 PM
12/30/13 10:46 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have a 64 Dodge that I want to start 275 racing. Currently a 583 B1mc motor but the rules are SB only for boost. What is the best heads and block to use for a boost combo? What parts are most available on the market. I have never built a SBM. I have always had BBM. I am looking to see if it makes sense to switch.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: What's the best small block heads/motor for boost?
[Re: 65 Hemi]
#1556388
12/30/13 11:01 PM
12/30/13 11:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would say R3 block 48* siamese cyl with a W-8 head.. the W-9 would be the next head only because the W-8 is so much beefier... the W-9 has a great flowing exhaust port for a turbo... both heads and the R3 block have the extra head bolts for better clamping force EDIT I'm selling my car and engine now but if it goes as a roller I'll be selling the engine on its own.. its a R3 block 48* siamese with a billet crank 3.79", fully ported W-9 heads and TD rockers, all good stuff.. PM me if interested (its in the for sale section)
[Re: dizuster]
#1556391
12/30/13 11:36 PM
12/30/13 11:36 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I'd say Gen 3 hemi is actually the best flowing head for small Cid right now. Ported 6.4l head will go over 400cfm for sure.
How much power? Stock 5.7 block is good for at least 1200hp.
I agree but your going to lift the heads with too much boost. Now I don't know if this is due to the material the head is made of, amount of bolt retaining the head, quality of fasteners or all the above. But THITEK has a G3 head that is physically beefier.
[Re: 65 Hemi]
#1556395
12/31/13 12:00 AM
12/31/13 12:00 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
4.50's 3200lbs= 1900hp and an outstanding suspension.I know this to be true my good friend did that last yr in x275.BB nos car
I think a 400ci Pro charged BES piece would get you 1500 or so.I'd be lying if i knew who could build a sb mopar that stout.
[Re: 65 Hemi]
#1556398
12/31/13 12:37 AM
12/31/13 12:37 AM
Posts: 636 Central,Ohio
FASTFISH420
Central,Ohio
I was going to convert mine to F2 pro charged on alcohol Uratchko and Steve Morris said it would make 1750 horsepower.. that is at 416 cubes with 10 degree pro stock head
1969 Barracuda 8 second all/motor small block
2014 Shelby GT500 Mustang
Uratchko Racing Engines
www.URE-RACING.com
[Re: W5DART66]
#1556406
12/31/13 02:05 AM
12/31/13 02:05 AM
65 Hemi
San Diego CA
What do you think this motor will do set up for boost. New piston and cam with a Procharger or turbo? http://www.racingjunk.com/Drag-Racing/182074121/440-all-aluminum-w8-small-block-mopar.html
Doug
