What's the best small block heads/motor for boost? #1556387
12/30/13 10:46 PM
12/30/13 10:46 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I have a 64 Dodge that I want to start 275 racing. Currently a 583 B1mc motor but the rules are SB only for boost. What is the best heads and block to use for a boost combo? What parts are most available on the market.
I have never built a SBM. I have always had BBM. I am looking to see if it makes sense to switch.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556388
12/30/13 11:01 PM
12/30/13 11:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would say R3 block 48* siamese cyl with a W-8 head..
the W-9 would be the next head only because the W-8
is so much beefier... the W-9 has a great flowing exhaust
port for a turbo... both heads and the R3 block have
the extra head bolts for better clamping force
EDIT
I'm selling my car and engine now but if it goes as
a roller I'll be selling the engine on its own..
its a R3 block 48* siamese with a billet crank 3.79",
fully ported W-9 heads and TD rockers, all good stuff..
PM me if interested (its in the for sale section)
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556389
12/30/13 11:09 PM
12/30/13 11:09 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
If its a turbo your not gonna need that much ci i would go with w7 15* heads,the deck is super thick 3/4 " so its not gonna lift & there an 18 bolt head.Short deck r3 or same thing mopar restoration block.I think with the w7 you'll get 375cfm and good exh #'s also.
I know someone with 3 sets of w7 heads and brand new blocks,i saw 2 blocks in the garage recently.
Re: What's the best small block heads/motor for boost? [Re: fishy340] #1556390
12/30/13 11:18 PM
12/30/13 11:18 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I'd say Gen 3 hemi is actually the best flowing head for small Cid right now. Ported 6.4l head will go over 400cfm for sure.
How much power? Stock 5.7 block is good for at least 1200hp.
Re: What's the best small block heads/motor for boost? [Re: dizuster] #1556391
12/30/13 11:36 PM
12/30/13 11:36 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I agree but your going to lift the heads with too much boost. Now I don't know if this is due to the material the head is made of, amount of bolt retaining the head, quality of fasteners or all the above. But THITEK has a G3 head that is physically beefier.
Re: What's the best small block heads/motor for boost? [Re: dizuster] #1556392
12/30/13 11:37 PM
12/30/13 11:37 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I will need to make about 1700-1800 HP. How about the P7 NASCAR stuff???
Doug
MOPAR or NO CAR!!!
Re: What's the best small block heads/motor for boost? [Re: fishy340] #1556393
12/30/13 11:40 PM
12/30/13 11:40 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I'm thinking Procharger or 1071Roots. I will need to run 4.50s in the 1/8 at 3200lbs around here.
Doug
MOPAR or NO CAR!!!
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556394
12/30/13 11:46 PM
12/30/13 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My next question would be, do they let you run any rear
suspension or are you stuck with leafs
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556395
12/31/13 12:00 AM
12/31/13 12:00 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
4.50's 3200lbs= 1900hp and an outstanding suspension.I know this to be true my good friend did that last yr in x275.BB nos car
I think a 400ci Pro charged BES piece would get you 1500 or so.I'd be lying if i knew who could build a sb mopar that stout.
Re: What's the best small block heads/motor for boost? [Re: MR_P_BODY] #1556396
12/31/13 12:06 AM
12/31/13 12:06 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Can run ladder bars but some ladder bars have an adjustable top bar like a 4 link but it connects to the lower bar in front.
Doug
MOPAR or NO CAR!!!
Re: What's the best small block heads/motor for boost? [Re: fishy340] #1556397
12/31/13 12:11 AM
12/31/13 12:11 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I know a local guy makes 1800 HP with a SBC and runs 4.50- 4.60s. I think I may be out gunned with a mopar. I think there is a guy in TX with a new Challenger with turbo w8 that may be in the hunt but I think it would be cool to do it with old metal mopar (64 B-body).
Doug
MOPAR or NO CAR!!!
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556398
12/31/13 12:37 AM
12/31/13 12:37 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I was going to convert mine to F2 pro charged on alcohol Uratchko and Steve Morris said it would make 1750 horsepower.. that is at 416 cubes with 10 degree pro stock head
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556399
12/31/13 12:39 AM
12/31/13 12:39 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I agree it would be cool to see a mopar doin it.My friend Petey sb has the record for sb Mph in x275..car is 2750lb and makes right around 975hp MOTOR with sb2 heads.
Best of luck bud,i personaly would love to see this done with a mopar.The car in TX is Marty and he'll be the first to tell ya its a HUGE amnt of coin to do what he's done with a p5 sb hemi head.
Good luck man!
Re: What's the best small block heads/motor for boost? [Re: FASTFISH420] #1556400
12/31/13 12:42 AM
12/31/13 12:42 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I don't think John Sears allows a 10* head in x275. I could be wrong and if it is allowed it would have to weigh a ton in penalties.
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556401
12/31/13 12:49 AM
12/31/13 12:49 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Around here the most competitive X275 cars are BB on N20. That's just what I've seen here.
Re: What's the best small block heads/motor for boost? [Re: SLOW67] #1556402
12/31/13 01:11 AM
12/31/13 01:11 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
All the sb ford stuff is only 4 bolts per cylinder and they can run big boost in those. Not sure why a hemi couldn't do the same thing?
I'm not sure if the open deck r5 block will take a ton of boost. Maybe with darton sleeves it would work?
Or if you could get an xr block you could use a p7 head?
The duster from Texas (marty) doesn't have w8 heads. Now it's got billet p5 heads.
Re: What's the best small block heads/motor for boost? [Re: fishy340] #1556403
12/31/13 01:22 AM
12/31/13 01:22 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I don't see any thing about SB heads being limited on the X275 rules.
Doug
MOPAR or NO CAR!!!
Re: What's the best small block heads/motor for boost? [Re: SLOW67] #1556404
12/31/13 01:25 AM
12/31/13 01:25 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I have a legal 583 B1MC motor that make 1149HP plus NOS but I don't think it will hang with brand X.
Doug
MOPAR or NO CAR!!!
Re: What's the best small block heads/motor for boost? [Re: 65 Hemi] #1556405
12/31/13 01:44 AM
12/31/13 01:44 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
PM me I have the w8s that you will need to do this.
Re: What's the best small block heads/motor for boost? [Re: W5DART66] #1556406
12/31/13 02:05 AM
12/31/13 02:05 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What do you think this motor will do set up for boost. New piston and cam with a Procharger or turbo?
http://www.racingjunk.com/Drag-Racing/182074121/440-all-aluminum-w8-small-block-mopar.html
Doug
MOPAR or NO CAR!!!
