Re: Stroker Hemi combos, ET/power #s
[Re: 408cuda]
#1554968
12/31/13 02:34 PM
12/31/13 02:34 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
572" hemi, KB block, MP heads CNC'd by MCH. 11:1 compression for pump gas. Solid roller spec'd by Dwayne Porter...mild grind to be easy on parts. Ray Barton single 4500 intake, 1200 pro systems dominator. 727, custom 5k stall, 4.10 gear, 295-65 drag radials. Cal-tracs rear suspension. 3800+ lb. '70 cuda, footbraked, full interior, street car. 9.54 at 140.4 mph, 1.320 sixty foot. All motor.
[Re: an8sec70cuda]
#1554969
12/31/13 02:37 PM
12/31/13 02:37 PM
an8sec70cuda
[Re: 408cuda]
#1554970
12/31/13 03:45 PM
12/31/13 03:45 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine is an all aluminum 496 Indy Maxx block.On the dyno it made 974 hp @ 6500 on 10 pounds of boost...got it home jetted it down 2 sizes and changed to 10 percent over and it made 14 pounds of boost so it should be around 1100 hp. 4.25 gun drilled callies xl crank. Oliver rods 4.31 Ross Pistons/8.2 compression Indy Legend-1 CNC heads Dick Landy Rockers Bullet/Morris roller cam Intake .707/272@.050 Ex .684/280@.050 Comp lifters Smith Bros push rods Charlies pan with swinging pickup Milidon pump and single line cover Supercharger USA Teflon stripped 10-71 2 Quick Fuel 1050 dominators Mezeire high volume water pump PTC Spragless convertor Before install...... In the car.....
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Dragula]
#1554975
01/07/14 03:34 PM
01/07/14 03:34 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Awesome thread. Who has the biggest cu in HEMI? Who's is making the most power? My KB HEMI is far from finished so i must live thru all of you for now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
