Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554968
12/31/13 02:34 PM
12/31/13 02:34 PM
an8sec70cuda Offline
572" hemi, KB block, MP heads CNC'd by MCH. 11:1 compression for pump gas.
Solid roller spec'd by Dwayne Porter...mild grind to be easy on parts.
Ray Barton single 4500 intake, 1200 pro systems dominator.
727, custom 5k stall, 4.10 gear, 295-65 drag radials. Cal-tracs rear suspension.
3800+ lb. '70 cuda, footbraked, full interior, street car.
9.54 at 140.4 mph, 1.320 sixty foot. All motor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Stroker Hemi combos, ET/power #s [Re: an8sec70cuda] #1554969
12/31/13 02:37 PM
12/31/13 02:37 PM
launch
CHIP
Re: Stroker Hemi combos, ET/power #s [Re: 408cuda] #1554970
12/31/13 03:45 PM
12/31/13 03:45 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Mine is an all aluminum 496 Indy Maxx block.On the dyno it made 974 hp @ 6500 on 10 pounds of boost...got it home jetted it down 2 sizes and changed to 10 percent over and it made 14 pounds of boost so it should be around 1100 hp. 4.25 gun drilled callies xl crank.
Oliver rods
4.31 Ross Pistons/8.2 compression
Indy Legend-1 CNC heads
Dick Landy Rockers
Bullet/Morris roller cam Intake .707/272@.050 Ex .684/280@.050
Comp lifters
Smith Bros push rods
Charlies pan with swinging pickup
Milidon pump and single line cover
Supercharger USA Teflon stripped 10-71
2 Quick Fuel 1050 dominators
Mezeire high volume water pump
PTC Spragless convertor
Before install......
In the car.....
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Stroker Hemi combos, ET/power #s [Re: 67HEMI] #1554971
12/31/13 06:48 PM
12/31/13 06:48 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wow....I have the smallest Hemi on here...
Re: Stroker Hemi combos, ET/power #s [Re: Dragula] #1554972
12/31/13 07:41 PM
12/31/13 07:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
how about the small bore strokers 4.25-4.31x4.5, any comments
Re: Stroker Hemi combos, ET/power #s [Re: cudaman1969] #1554973
01/06/14 09:23 PM
01/06/14 09:23 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Guys, awesome combo's I've also noticed that 99% of you are running Firecore Wires. Thanks much. I finally get to see some of your combos. Below WAS mine. I am transplanting the Hemi into something a lot lighter. It was a 71 GTX. 4100 with me. 472, 10.75 to 1 re-worked crate. Indy rollers, 650 Cam Motion, Dominator, full 3" exhaust. Ran 5 10.81's @ all around 129 last time I ran it. Click below for a video at the YellowBullet Nats in Maryland.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Stroker Hemi combos, ET/power #s [Re: Hemi Allstate] #1554974
01/06/14 10:28 PM
01/06/14 10:28 PM
Dragula Offline
Dragula  Offline
As soon as the weather allows...I will pull the intake and make the proper clearances to make this baby work...So making 660hp NA with an unsorted out 484 pump gas combo, going to make more very soon..
Re: Stroker Hemi combos, ET/power #s [Re: Dragula] #1554975
01/07/14 03:34 PM
01/07/14 03:34 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Awesome thread. Who has the biggest cu in HEMI? Who's is making the most power? My KB HEMI is far from finished so i must live thru all of you for now.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
